1994 delanair troubles (ac/upper part)
Old Oct 14, 2025 | 07:48 AM
yoopas's Avatar
Default 1994 delanair troubles (ac/upper part)
Guys, maybe we have Late 1994 delanair system pro's here.
Upper part of blower seems not be operative as it should - nor internal blower regulator motor is working (Although itself it's working separately) nor upper blower flap is opening and closing correctly (physically/mechanically works fine).
It seems like the system is not controlling upper part at all.
Blending on footwell part works absolutely perfect - cold or hot if required comes as requested.
Any help?
Old Oct 14, 2025 | 01:07 PM
Jagboi64's Avatar
That flap will only open when air conditioning is called for. For heat or defrost it stays closed. It also takes a while to stabilize, it can be up to a minute for that flap to open once the AC starts blowing cold.
Old Oct 14, 2025 | 07:17 PM
baxtor's Avatar
I second what Jagboi64 says, also check the flap is not physically stuck in place. The foam sealing strip quite often breaks down into a gooey sticky mess and holds it closed.
Old Oct 15, 2025 | 12:51 AM
yoopas's Avatar
dear @Jagboi64 and @baxtor - air circulation went is always in COLD position (open only for cold air). I've checked the motor separately - it's working. But it's not working while connected in the car.
All foam is cleaned.
Center air went is not opening as well.
Seems more like electric problem...
Although as mentioned - bottom air circulation (Footwell) is working absolutely fine.
Old Oct 15, 2025 | 01:28 AM
baxtor's Avatar
Have you checked the vacuum system and solenoids.
Old Oct 15, 2025 | 01:31 AM
yoopas's Avatar
Solenoids - physically working fine. Each (there are 2) working separately one from another and opening physically valves. Though - center went is not opening automatically from vacuum. Demist - works from button perfectly.
Vacuum lines are keeping vacuum and seems to be intact.
Old Oct 15, 2025 | 02:59 AM
baxtor's Avatar
You may have these resources already but in case not, here they are.
File Type: pdf
File Type: pdf
Old Oct 15, 2025 | 03:35 AM
yoopas's Avatar
Dear @baxtor thank you for the information provided.
Previously i've fully rebuild this box - new AC condenser + new heater matrix. Maybe during assembly i've wrongly installed the upper flap and thus it's working incorrectly.
JeremiahLovesJags
Jun 9, 2022 08:42 AM
sedonajag
E type ( XK-E )
Jun 1, 2022 11:49 AM
sradcock2888
Aug 16, 2018 03:28 PM
tomscob
Nov 14, 2011 07:25 PM
