1995 XJS convertible top fluid
Old Aug 7, 2017 | 06:45 PM
bh6pack's Avatar
Default 1995 XJS convertible top fluid
I just purchased a 1995 jag xjs 6 cylinder. Fluid is leaking from between the reservoir and the pump. I would like to know what the gasket looks like. Does anyone have a picture? Also, what fluid should i use? The local Jag dealer sold me Castrol 27LM9886 .(green fluid) I was told not to use this, after I put in a little to get the top up. Now do I have to flush the system? and How would I do that.
Any help would be appreciated.
Thanks, Ben
Old Aug 8, 2017 | 02:44 AM
Welcome to the forum bh6pack,
I've moved your question from XJ6 & XJ12 Series I, II & III to XJS forum. Members here with the same model will be able to help.
Old Aug 8, 2017 | 11:19 AM
bh6pack's Avatar
thanks so much. after I posted it I realized I did in the wrong place
Old Aug 8, 2017 | 04:51 PM
orangeblossom's Avatar
Thanks, Ben
Hi I think that Malc suggested Royco 756
Royco 756 Aircraft Hydraulic Fluid - SkyGeek.com
Old Aug 9, 2017 | 12:50 AM
Jagboi64's Avatar
Spec is an ISO 13 viscosity anti wear hydraulic oil. The green Castrol oil is intended for the mineral oil systems in the 1988-94 sedans ( code named XJ40) and is the wrong oil for the system. It's too thick and will put additional strain on the pump. Depending on the amount and temperatures, I have heard of pump failures from using it.
If you live in a hot climate and didn't put much it, it will probably be fine. I don't have a diagram at hand, but I think it's an O ring for the seal? Not sure. If it's flat, you could use something like Loctite 515 Flange Sealer.
I have found aircraft hydraulic oil, generically known as 5606 spec is the right viscosity. It comes in A and H grades, A is an older spec, H is for "super clean" aircraft systems. Either works, use whatever you can find and is cheaper.
JimC64
Sep 22, 2025 02:52 PM
Sep 9, 2017 06:52 AM
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
Jan 20, 2011 04:14 AM
