1996 XJS Runs rough after acceleration
Old Apr 14, 2010 | 04:18 PM
drat9000's Avatar
Question 1996 XJS Runs rough after acceleration
My 96 XJS 4 liter runs beautifully most of the time. However if I 'floor it' 2 or 3 times in a row it will then idle rough or stall out and the catlytic converters start to glow red hot. If I let it sit overnight it starts up and runs fine. Engine temp reads normal the whole time. If I don't push it hard, I can maintain highway speed and drive in stop and go for an indefinite time with no problems. Again, if I don't accelerate too rapidly all is well. And if I do it seems fine till I slow down. Thoughts?
Old Apr 16, 2010 | 09:05 AM
sodium's Avatar
Sounds like overfuelling. I would start by checking the air-mass meter and fuel pressure regulator.
Old Apr 16, 2010 | 09:27 AM
sodium's Avatar
I did a quick check through the manual and found the diagnostic section for the air-mass meter. They're calling it an air-flow meter. It's on page 31 of this manual and lists the voltages and expected behaviors.
"http://captainsodium.com/Private/XJS-Manuals/ServiceManuals/04 Engine Management 4.0 litre.pdf"
You could also have plugged converters. Try taking it out and running it on the highway for an hour or two. That may heat the catalysts enough to ash-off any accumulations.
Old Apr 21, 2010 | 09:37 AM
drat9000's Avatar
Default link to pdf not readable
Thanks for the reply Sodium. Unfortunately I can't get the URL in your post to work for me. Would love to see it so I could get a handle on where to start. Thanks again!
Old Apr 22, 2010 | 10:50 AM
sodium's Avatar
I put an extra hyphen in there. This works.
http://captainsodium.com/Private/XJS...erviceManuals/
Old Apr 23, 2010 | 10:30 AM
drat9000's Avatar
I've tried IE and Firefox, still no luck. Farthest I can get without a 404 is http://captainsodium.com/Private/ Is it small enough to email?
Thanks again
Old Apr 27, 2010 | 11:40 AM
sodium's Avatar
alright. I pulled the space out of the url. This should provide you with nothing but happiness.
http://captainsodium.com/Private/XJS/
Old Apr 27, 2010 | 12:39 PM
Sodium thanks for providing the link. Works for me;-)
PM sent.
Old Apr 28, 2010 | 01:51 PM
drat9000's Avatar
Sodium,
Got 'em. Thanks so much. I'll be under the bonnet this weekend.
toronadomike
Jan 22, 2026 10:13 PM
Gus
Oct 15, 2019 12:29 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
XFR_Gold
Sep 2, 2015 12:24 PM
XJsc-guy
Sep 2, 2015 11:43 AM
