2nd small tank and carb setup
Old Jun 21, 2014 | 12:27 AM
Bc xj's Avatar
Default 2nd small tank and carb setup
Do I need that second small tank under battery if Im running carbs. I believe it is a circulating tank for fuel injection. I would like to remove if possible.
Old Jun 21, 2014 | 01:01 AM
ptjs1's Avatar
Bc xj,
I think you're referring to the anti-swirl pot in which case, I think you'll need to retain it. The anti-swirl pot mitigates for a lack of baffling in the main tank and allows the fuel to pull from a smaller constantly full container.
Others may have alternate views but I think that even wit carbs you should keep it.
Paul
Old Jun 21, 2014 | 05:37 AM
I see no reason for it with a carby fuel pump. Remove that tank, mount the pump in there, with a filter in the 12mm supply hose FROM the tank.
OK, some starvation MAY occur with less than 1/4 tank of fuel in TIGHT/FAST corners, when the main tank fuel will slosh to the side of the tank, and away from the drain spigot, Since carbies have a fuel bowl, and their own SMALL supply of fuel, you may not even feel any hesitation.
I had a 1977 V12 EFI here a looooong time ago for some work, with the EFI pump was mounted there, as his sump tank had rotted out, and this was his fix. Ran perfectly fine, and he was the one that mentioned the 1/4 tank of fuel as a safe LO level. He never had starvation issues, and drove that car HARD.
dsnyder586
Dec 29, 2024 07:39 PM
rusty37
Sep 18, 2015 10:03 AM
Tim Goz
Sep 17, 2015 09:11 AM
1LowCat
Sep 14, 2015 07:51 PM
hen555
Sep 7, 2015 11:13 PM
