5.3L V-12 Firing Order
Old Sep 9, 2017 | 08:14 AM
Doug's Avatar
Saliah,
If you haven't done so already now would be the time to remove the distributor cap and take a peek at the rotor....as they often burn through. With the cap off you'll also see that the Marelli rotor and distributor cap are a dual plane design which explains why the actual firing order of the cylinders is the same as a Lucas ignition car but the placement of the wires on the distributor cap is different.
Old Feb 4, 2022 | 01:01 AM
Series2's Avatar
Smile
Originally Posted by JigJag
I can't edit my post above to add a better picture of the vertical HT lead routing so I suppose I'll just post it down here.
Looks very good. I might do that too.
Old Jul 14, 2022 | 05:52 PM
808PUNABOY's Avatar
I'm trying to work out a new routing for my HT ignition leads. Trying something new and I needed a visual aid. I thought I'd post it for others who might find it useful.
Jaguar 5.3L v-12 firing order gif
I have a 94' XJ12 V12 Marelli - except the "B1" cylinder is clearly forward of the passenger side bank..... yet isn't ALL engines most forward cylinder no.1 ?
Old Jul 14, 2022 | 07:18 PM
808PUNABOY's Avatar
Ok, very interesting. Here's the Marelli version, based on comments and images of the cap and dizzy. Let me know if I've got it wrong in some way.
Jaguar 5.3L V-12 Marelli firing order gif
is the Distro position correct on this gif? ie: are the firing order on cap, actual position on vehicle?
Old Jul 14, 2022 | 07:33 PM
garethashenden's Avatar
The XK engine is numbered from back to front.
Old Jul 14, 2022 | 10:12 PM
Doug's Avatar
The firing order is 1A,6B,5A,2B,3A,4B,6A,1B,2A,5B,4A,3B
But since the Marelli system has a two plane rotor, the numbers on the cap are 1A,1B,5A,5B,3A,3B,6A,6B,2A,2B,4A,4B
#1 cylinder on a Jag V12 is "1A", which is front most cylinder, RH side
Weird, I know
Doug's Avatar
Yes, but the V12 is not an "XK" engine :-)
Old Jul 14, 2022 | 10:14 PM
  #28
Doug's Avatar
If you have Lucas ignition (as opposed to Marelli) it looks like this
Old Jul 15, 2022 | 02:07 AM
baxtor's Avatar
Weird, I know
Genuine question Doug. Why is it "weird", what am l missing?
Old Jul 15, 2022 | 07:19 AM
  #30
Doug's Avatar
The norm is that the layout of the wires on the cap matches actual firing order of the cylinders, as seen in the illustration of the Lucas system.
On Marelli system, with the dual plane, dual tipped rotor, the layout of wires on the cap does not match the firing order of the cylinders. Which is weird
The "A bank" - "B bank" numbering system is also a little weird. I'm not aware of any other V-type engine using this system....but I could be under-informed on that!
And, typically, the #1 cylinder (for the purposes of engine timing, finding TDC, and such) is the front-most cylinder of the front most cylinder head (the head that is further forward on the engine block). The uninitiated, working on a Jag V12, would go to 1B when in fact they should be going to 1A.
Old Jul 15, 2022 | 08:09 AM
  #31
baxtor's Avatar
Fair enough.
I think you would agree however that to the initiated (as opposed to the UNinitiated) all things Jaguar make perfect sense.
Old Jul 15, 2022 | 08:14 AM
  #32
Doug's Avatar
Fair enough.
Naturally
brinny
Aug 17, 2021 06:38 PM
XJCCAT
E type ( XK-E )
Aug 2, 2021 06:31 AM
dstarr3
Sep 10, 2017 11:11 PM
Doug
May 14, 2017 07:31 PM
davisalln
Sep 21, 2013 05:23 PM
