50/50 Pre-Diluted Dex-Cool coolant in XJS
Old Jun 22, 2013 | 05:20 PM
Agent 00714's Avatar
Default 50/50 Pre-Diluted Dex-Cool coolant in XJS
Hi again,
Is 50/50 Pre-Diluted Dex-Cool antifreeze mixture OK for my 95 XJS 4.0?
If not, any suggestions?
Thanks in advance
Old Jun 29, 2013 | 09:45 AM
RagJag's Avatar
Don't know if Dex-Cool is any better for our cars. I use plain old Prestone in mine albeit the pet safe kind. Cheers.
RagJag
Old Jun 29, 2013 | 12:07 PM
dsetter's Avatar
I believe that on a 95 that ZEREX G05 coolant is better. Lower erosion and better water pump lubrication and less glugging.
Old Jun 30, 2013 | 09:00 AM
RagJag's Avatar
Water pump lube from coolant is a myth. Pump bearings are sealed. No coolant gets into the bearings. If it does the seal has failed and will leak coolant.
Cheers, RagJag
Old Jun 30, 2013 | 09:02 AM
RagJag's Avatar
DSETTER, what is glugging??
RagJag
Old Jul 1, 2013 | 01:00 AM
AL NZ's Avatar
You need to google types of antifreeze - I did this yesterday, by coincidence
I believe DexCool is an OAT type coolant (Organic acids) as opposed to the old style coolant or HOAT - again, google it.
I think the concern with OAT antifreezes is they don't mix with older style inorganic acid coolants, and you must totally flush the whole system rather than mix them.
So it depends what is in your system already, and how prepared you are to fully flush the system.
I use Total Glycelf Supra (or my mechanic does!) This is apparently a top product (according to Total's literature..)
Good antifreeze is critical for the Jag engines. 50/50 mix is ideal, unless you live somewhere really cold.
Old Jul 1, 2013 | 08:12 AM
Spikepaga's Avatar
I use the the lemon lime Gatorade colored Jaguar anti freeze on my 95 XJS
Old Jul 1, 2013 | 08:33 AM
ronbros's Avatar
I use EVANS waterless coolant, absolutly no boiling or hot spots, 375*F boiling point, has no water in it, so NO corrosion, and is a lube, good for seals.
non toxic for enviroment, a lifetime coolant.
had it in one of my cars for 8yrs, never a problem. sold the car probably still in it 11yrs.
Old Jul 1, 2013 | 08:35 AM
ronbros's Avatar
google ;EVANS WATERLESS COOLANT.
Old Jul 1, 2013 | 05:46 PM
RagJag's Avatar
That stuff is rather costly, isn't it?
RagJag
Old Jul 1, 2013 | 06:20 PM
ronbros's Avatar
good stuff is never cheap!
untill you blow a headgasket, or crack a head or block
1100me
Jul 24, 2023 06:10 PM
Rivguy
Dec 4, 2020 07:55 AM
Wahooesprit
Dec 23, 2019 02:01 PM
ogorir
Jan 18, 2016 10:09 PM
1100me
Sep 7, 2015 06:26 AM
