76 Spline 1" steering wheel hub adapter avallable?
Old Jan 23, 2014 | 11:16 PM
dsetter's Avatar
Default Solved. Steering wheel hub adapter avallable?
I have a '95 with airbag steering wheel and would like a wood steering wheel.
I have pulled the wheel off and it has a large shaft about 26mm and 76 spline count as counted and molded into the original wheel.
I see that many Nardi/Personal hub adapters are available for the earlier years with smaller shafts.
Does anyone have an adapter or know what might fit onto these shafts?
Else, I think I will have a nice early Nardi Wood wheel for sale for the small shaft.
Old Jan 24, 2014 | 10:48 AM
Greg in France's Avatar
Try contacting Motalita.
Greg
Old Jan 25, 2014 | 11:28 PM
dsetter's Avatar
Default Solved
Well what do you know, the 76 spline was already adapted from the shaft so is the same as an earlier XJS shaft. I was able to cut the early hub adapter down and it fitted on to the 95 shaft fine.
I added a turn cancel block on the side of the hub for the cancel function and shaved the console size to fit the hub
The only thing is that I have not yet worked out a horn wiring as the original had a sliding slip ring.
This Nardi wheel can be set with either a wooden Center or Metal spoke
Thsi still needs a Jag logo in the center.
Anyone let me know if you want any details.
I am happy with the change.
H20boy
Dec 24, 2024 03:23 PM
RobertTheBloke
Sep 24, 2015 11:48 AM
Burdedw
Sep 12, 2015 10:39 AM
iownme
Sep 11, 2015 02:57 AM
innzane
Sep 2, 2015 10:08 AM
