84 xjs No start....HELP!
Old Jul 27, 2010 | 07:41 PM
Brian Felts's Avatar
Default 84 xjs No start....HELP!
Guys need lots of help. I had a question on here about a no cold
start situation. The car would after long cranking would start and
run good at 1200 rpm.
I replaced the Aux Air Valve and now it will not start just
cranks. I can get it to hit and run if I hold down on the gas pedal
but then the idle jumps from 700 to 1300. What can I check now? I
can hear the fuel pump...everything looks connected.
Brian Felts
Old Jul 27, 2010 | 09:54 PM
Doug's Avatar
Do you have spark?
Are the injectors clicking when you crank?
Post back
Old Jul 28, 2010 | 04:00 AM
Now it is starting on the first try...........BUT the idle is just jumping up and down (700 to 1200 rpm) when I begin to open the throttle it just boggs it down and will not rev the motor at all.
Thanks again
Brian Felts
Rivguy
Dec 4, 2020 07:55 AM
CXJ
Nov 28, 2015 11:41 PM
hoodun
Sep 26, 2015 11:41 PM
alextoevs
Sep 20, 2015 05:21 PM
XJsc-guy
Sep 2, 2015 11:43 AM
