89 XJS No Speedo but Tach and Dist Seem Okay
Old Jun 23, 2021 | 01:52 PM
LooseMetal's Avatar
Default 89 XJS No Speedo but Tach and Dist Seem Okay
As the title says, the speedo went intermittent, then more off than on. When on, it's correct. The Tach reads okay, and the trip computer distance advances. VIN is 158578. It has the speed sensor on the back plate of the differential.
I thought I would first reseat the connectors, but where is the transducer interface unit mounted? The wire from the transducer goes up through the trunk behind the spare, and then reenters the body cavity.
Other thoughts?
Thanks!!
Old Jun 24, 2021 | 02:38 AM
orangeblossom's Avatar
Hi Loose Metal
If you follow that Wire in the Boot/Trunk where it goes into the Cavity, then you will find the little Black Speedo Interface Box although its well hidden away and you may have to move the ECU or even unbolt that metal plate to get to it
Location of the 'Speedo Transducer' 89 XJS
Having said that your problem with the 'Speedo' is far more likely to do with some corrosion on the Pins of the 'Multi Plugs' that plug into the back of the 'Speedo Binacle' here is how to remove the 'Speedo Binnacle' in order to clean them (which also fixed my intermittent 'Speedo' with the same problem as yours)
Fixing my Non Working 'Speedo' 89 XJS V12
Old Jun 26, 2021 | 07:37 PM
LooseMetal's Avatar
Default Jag Speedo Fixed !!!
Hi Orange Blossom,
Thank you SO MUCH for the tip to clean the connectors on the back of the instrument panel. I suspected connectors when it first started getting intermittent, but I didn't know how to get to them, and was reluctant to poke around without some expert guidance. So the link to the other thread with the photos was perfect. And as you can see in the photo: problem solved!!! I also learned a new word—binnacle.
Warmest regards,
Eric
Old Jun 27, 2021 | 12:51 AM
Hi Eric
Don't thank me thank the GF aka 'Clever Clogs!' as apparently my small contribution was of limited use!
Anyway glad you got it fixed, nothing more frustrating than a dodgy Speedo and 'Binnacle' crept into the mix from when I used to have a boat which cost me far more to run than any amount of XJS's and nowhere near as much fun!
sconce01
Dec 3, 2019 11:22 PM
Kariblay
Jul 30, 2019 06:36 AM
dickc
Sep 8, 2015 08:15 AM
mlp442009
Feb 15, 2014 12:33 AM
Blake Caldwell
Aug 15, 2013 04:54 AM
