94 antenna fuses
Old Dec 13, 2015 | 07:44 AM
kentmcnorton's Avatar
Default 94 antenna fuses
I have the manuals, and I know there is an inline fuse, but I cannot find it. Can someone tell me where it is located? Also, which fuse box and fuses control the antenna. LH drive
Old Dec 13, 2015 | 08:37 AM
Greg in France's Avatar
On an pre facelift the inline fuse is in the wiring nearby the aerial motor itself, in the RHS rear wing in the space between the exhaust tunnel and the outer steel wing panel itself. On a pre-facelift, If you remove the carpet/liner there you will see it. If your aerial is in the rear LHS wing that might be where your fuse is.
Greg
Old Dec 13, 2015 | 12:46 PM
malc4d's Avatar
From the internet....
Check power to the radio - Fuse 4 (5A) and Fuse 5 (10A) on the left component panel in the cabin. Fuse 10 (10A) that protects the antenna circuit is located in the right rear fuse panel in the luggage compartment.
Feffman
Motorsports
Jul 9, 2016 06:18 AM
mutu88
Dec 16, 2015 03:10 AM
Valium.Skies
Dec 14, 2015 11:27 PM
obwoodie
Dec 12, 2015 10:01 PM
2007 Rick
Dec 12, 2015 11:03 AM
