'94 Jaguar XJS no crank
Old Aug 27, 2023 | 08:31 AM
orgullodemexico's Avatar
Default '94 Jaguar XJS no crank
Hello Jag lovers
It's Sunday morning, I am two hours away from home and my 1994 Jaguar XJS 6 cyl (76K miles) won't crank.
Battery and connextions are good.
I jiggled the gear shift selector, tried starting in nuetral, no crank. I know there is a safety switch which is made up when the car is in park. When I do turn the key to start I do hear a "click" inside the car.
I removed each of the relays and the 30 amp fuse in the teunk as shown in the pic, and the engine cranked and started. Dumb luck or do I have something else that I need to pursue when I return home? Starter solenoid and/or starter motor?
TIA
Old Aug 27, 2023 | 09:31 AM
Vee's Avatar
Vee
Dumb luck. Those relays are all for the convertible top.
JagRepair.com - Jaguar Repair Information Resource to get you electrical diagram.
Maybe you disturbed that battery, just below it? Any sign of corrosion on the terminals? Maybe a loose connection at the battery?
Old Aug 27, 2023 | 10:15 AM
ptjs1's Avatar
orgullodemexico.
As Vee says, those 6 relays can have no impact on the car starting. But there are relays and fuseboxes all over the car - both sides of the engine bay, under the dash on both sides, inside both rear wheel arches, behind the RH rear light etc. I'd really suggest you spend time understanding the car, the layout of all the fuses and relays, and what they all do. Don't consider running an XJS with out a full set of the wiring diagrams, workshop manuals etc.
Paul
Old Aug 27, 2023 | 10:38 AM
I have not touched the battery. Two months ago I wire brushed the posts and terminals and tightened everything.
If it was a battery problem, I would assume I wouldn't have lights, or hear a click inside when I turned they key.
Fsir assumption?
Old Aug 27, 2023 | 12:30 PM
equiprx's Avatar
Don' be so fast to discount what he did as not consequential.
If one of the convertible top circuits have a fault, it may disable the starter.
Do the lights dim when you try to start the car?
Old Aug 27, 2023 | 02:25 PM
Vee's Avatar
Vee
No. You can remove all of the relays and it will not affect the car's ability to start.
How old is the battery? It is plausible that it can no longer deliver the voltage needed to start it? These cars are finicky with having a proper charge on the battery?
That click you describe...is it from within the cabin, or from under the hood? You should hear a click when you depress the brake pedal. I'm trying to figure if the starter is stuck, or short of power.
Old Aug 28, 2023 | 10:43 AM
The battery was replaced 8/24/2022, so one year.
Key on, depress brake pedal and I hear a click in the cabin.
I have a hard time believing this car is that finnicky on battery power.
Because I've been able to stsrt only by sliding the gear selector back and forth, it sounds to me like the transmission mounter rotary switch which is priced at over $1000.00. Yikes!
Old Aug 29, 2023 | 09:59 AM
equiprx's Avatar
I would suggest getting into the console to see what's going on with that shifter.
Take a good look at the neutral safety switch.
orgullodemexico
Jul 30, 2023 08:44 AM
jagowner659
Jul 27, 2023 08:24 PM
Forgotten rides
May 25, 2022 06:32 AM
Arhabb II
Jun 23, 2020 07:07 AM
defaultuser
Jan 11, 2012 04:25 PM
