96 XJS Misfire
Old Feb 13, 2011 | 11:37 PM
Gandalfthegray's Avatar
Default 96 XJS Misfire
Hello, on my 96 XJS 4.0 I6 I have been experiencing a miss in the engine. At idle with the car in neutral it runs smooth, however if I shift the car into drive I feel a random misfire. It seems to occur only under a load. I can also feel the misfire when in neutral I kick the accelerator down. Plugs are just replaced. Could I have a failing coil pack? I have no codes on the dash.
Any thoughts?
Thanks,
Steve
Old Feb 14, 2011 | 07:50 AM
Doug's Avatar
Coil pack problems are not unusual as you know. As guesses go, it wouldn't be a bad place to start. Lacking a trouble code to identify which cylinder is misfiring you could buy one coil and just try it on all 6 cylinders. If one of the coils is bad you'll eventually find it :-)
Old Feb 14, 2011 | 11:15 AM
Thanks Doug.
I was thinking I may give this a try. Looks like I can buy a single coil pack as well. Is there any visual tell-tales for a bad coil pack? Burnt or cracked epoxy resin maybe?
duecedriver
Dec 25, 2015 11:47 AM
Jagged-X
Sep 24, 2015 05:08 PM
tsimms7
Sep 15, 2015 12:43 PM
Bcrary3
Sep 11, 2015 10:36 AM
corysansburn
Sep 10, 2015 06:15 AM
