96 xjs wiring help needed
Old Oct 11, 2020 | 04:48 PM
coldpad1's Avatar
Default 96 xjs wiring help needed
My xjs AC is not working. The light at the switch does not come on. Checked the fuses. There is no power at the compressor. Need to see where the power to the compressor comes from. Anyone have a wiring diagram they can share or point me to?
Old Oct 11, 2020 | 08:22 PM
equiprx's Avatar
There is too much difference between the 6.0 and the 4.0 to diagnose.
Old Oct 12, 2020 | 05:52 AM
coldpad1's Avatar
Sorry ....mine is the 4.0
Old Oct 12, 2020 | 09:33 AM
Vee's Avatar
Vee
jagrepair.com
Old Oct 12, 2020 | 10:11 AM
equiprx's Avatar
Unfortunatly, my experience is limited to the 6.0.
There are only two electrical connections that I know of.
One is to the compressor clutch and the other is an over pressure sensor.
Your system might not have the pressure protection of the 6.0.
I can also tell you that there are fail-safes designed to protect the system.
Either way, you should make sure both conditions are OK before proceeding.
Old Oct 12, 2020 | 11:01 AM
coldpad1's Avatar
Thank you ....
Old Oct 13, 2020 | 01:54 PM
Vee's Avatar
Vee
Originally Posted by coldpad1
Thank you ....
No problem, That website has a lot of great material stored. Looks like they had grander plans for it, but I'll take what I can get!
Old Oct 15, 2020 | 10:36 AM
lambo911's Avatar
You should still get a power feed to the A/C compressor clutch if you have the temperature set to cold . The pressure switch will not close to ground to complete the circuit if A/C gas is low.
You can also check the power to the clutch relay. Should have a permanent 12v with the ignition on and a 12v feed if the A/C is needed
Old Oct 25, 2020 | 10:38 PM
96xjsz's Avatar
I have an XJS. 1996 need. a wiring diagram
anyone please lost mine
Old Oct 26, 2020 | 08:52 AM
Vee's Avatar
Vee
See Post #4. Did you not read through the thread before asking this question?
Old Oct 27, 2020 | 07:48 AM
coldpad1's Avatar
Great site for sure
Old Oct 27, 2020 | 08:02 AM
jimbov8's Avatar
Here you go,
http://www.jagrepair.com/images/Auto.../jvs1995en.pdf
http://www.jagrepair.com/images/Auto.../jul1996en.pdf
one of each.
Old Oct 29, 2020 | 09:22 AM
mghirsch's Avatar
There is a low pressure cut off switch. Have you checked the pressures? You might have lost refrigerent..
Chop
New Zealand
Jan 6, 2020 07:22 AM
macudc
Jan 18, 2016 06:35 PM
sirreginald
Aug 18, 2015 08:43 AM
steve
Jul 31, 2012 06:43 PM
Project Jaguar
Aug 15, 2010 10:24 AM
