Aav
Old May 1, 2011 | 10:43 PM
i_like_ike's Avatar
Default Aav
Has anybody rebuilt their Aux. air valve. Difficult? Easier to buy a new one?
As a side note, I'm chasing down oil leaks and installing the Catcooler twin electrics fans. Pics to follow
Old May 1, 2011 | 11:32 PM
Doug's Avatar
I tried rebuilding mine...didn't work. Many have been sucessful, though, so don't let my failure stop you from trying. As of a few years ago a place in Austrailia (Prestige Spare, maybe?Can't remember) selling a rebuild kit.
Old May 2, 2011 | 03:25 AM
I have done many over the years, and only 1 was trashed.
NOT hard.
I have a paper with Kodaks in my laptop which I am happy to email to anyone who asks. My computer skills are rubbish at best, rather work on a Jag than play with this thing haha, so IF its not too complicated I will attach it here, IF it works good, if not back to my original suggestion of PM to those asking.
OK, just tried to "upload" the file via the attachment area I found, BUT it failed, must be too big, so PM seems the only way.
Old Feb 5, 2014 | 07:17 PM
Dr Quail's Avatar
Grant send me your write up on your rebuild, I have one done now, shoved the bulb in a couple of MMs, tested in hot water it closes completely......Is this a bad thing as the idle screw should supply enough air for the vac hose to the Dizzy cap (Lucas). Thought the wine cork with 3mm hole inserted might be a simpler solution. Best to you both, Jon and Gillian. PS. found miss in 5a after changing all plugs, it was brown..all others tan, JW.
Old Feb 5, 2014 | 08:15 PM
Mish_Mish's Avatar
I did mine 10 years ago with Volvo Penta marine thermostat actuator, works like a charm.
Old Feb 6, 2014 | 04:22 AM
Jon,
Email sent.
That dizzy vent hose has NO vac in it. It is simply a "draft" effect hose. The vac is on the inside of the AAV only, and the intake air to it via that elbow hose is purely a draft.
AHA, 5A, easy to replace, NOT. Good you found it.
The wine cork will work, ONLY if you consume the wine PRIOR to inserted it in the hole.
Enjoy
Last edited by Grant Francis; Feb 6, 2014 at 04:41 AM. Reason: spelling still sucks
Old Feb 6, 2014 | 05:11 AM
Originally Posted by Grant Francis
........ I have a paper with Kodaks in my laptop which I am happy to email to anyone who asks. My computer skills are rubbish at best, rather work on a Jag than play with this thing haha, so IF its not too complicated I will attach it here, IF it works good, if not back to my original suggestion of PM to those asking.
Grant,
If you eMail the file to me, I'll try resizing and adding to this thread.
Click on my user ID and select 'send email to GGG'
Greg
Aug 24, 2015 03:39 PM
Doug
Aug 6, 2015 07:55 AM
Dr Quail
Feb 5, 2014 07:21 PM
85V12JAG
Aug 29, 2013 10:29 AM
Japthug
Aug 7, 2013 02:45 PM
