air injection system - someone managed to remove the long pipe under RH manifold?
Old Oct 30, 2021 | 11:05 AM
coindigger's Avatar
Question air injection system - someone managed to remove the long pipe under RH manifold?
Hi,
I´m just about removing all the pipes and the auxiliary air pump.
Unfortunately I am stuck with the long pipe running underneath the RH exhaust manifold... I can´t pull it on neither side.
Did someone manage to remove this c46337 as one complete piece and without taking out the engine??
Cheers,
Tom
Old Oct 30, 2021 | 11:09 AM
Doug's Avatar
I just abandoned it in place.
Old Oct 30, 2021 | 11:41 AM
coindigger's Avatar
Yes, this would be the best choice.
Unfortunately I have someone who wants the complete undestroyed kit...
Old Oct 30, 2021 | 01:53 PM
jal1234's Avatar
I did the same. I think the only way to get it out is to remove the engine.
Old Oct 30, 2021 | 02:30 PM
coindigger's Avatar
In The Kirby Palm you find:
"If you ever have the right side exhaust manifolds off for some reason, you can remove it then."
Is someone able to confirm this... ?
Old Oct 30, 2021 | 09:38 PM
Engine out is the way.
Even the RH exhaust manifold off is a mammoth task, engine out is easier again. Maybe not so hard on LHD, but a PITA on RHD.
Old Oct 31, 2021 | 02:39 AM
coindigger's Avatar
Okay, thanks, I c.
Kind of a dilemma decision...
Old Nov 3, 2021 | 12:55 PM
coindigger's Avatar
Okay, gave it up...
...though there might be a chance for the LHDs to get those rear manifolds out by countering the nuts.
Buuuut, the event of having a broken bolt sitting there... led me to arrange my needs in an other way.
Tom
Old Nov 4, 2021 | 03:09 AM
BradsCat's Avatar
Engine out is the only real way.
I have one from the motor I took out last year. I don't need it.
Old Nov 4, 2021 | 03:11 AM
BradsCat's Avatar
I have one from the motor I pulled out of the 88 XJS 'cpnvert last last year.
Let me know. I sure don't need it.
Old Nov 4, 2021 | 02:19 PM
coindigger's Avatar
Thank you so much Brad!
I just bought one in the UK a couple of hours before...
Old Nov 7, 2021 | 03:54 PM
coindigger's Avatar
That way worked out...
retroren
Jul 29, 2024 07:55 AM
BradsCat
Jun 19, 2020 12:58 AM
Rhett
Aug 14, 2014 10:47 AM
bonnietiler
May 28, 2014 07:27 AM
Jagxjs
Feb 5, 2013 06:14 PM
