Air temperature switch A bank side air filter box?
Old Apr 5, 2017 | 02:19 PM
Daim's Avatar
Default Air temperature switch A bank side air filter box?
Hey guys,
what is the air temperature switch on the A bank side air box got for a function?
It was fitted to engines from 64245 onwards... I wouldn't be surprised if it is a Marelli specific part...
Number is DAC5061
Any ideas? Sure, temperature, but isn't that what the B bank temperature sensor is for? As it is a switch, something must be switched on/off!?
Damien
Old Apr 5, 2017 | 02:27 PM
that guy's Avatar
All I know is that my car ran poorly when it was disconnected.
Old Apr 5, 2017 | 02:32 PM
Daim's Avatar
Okay, so it serves a purpose, just what kind?
Old Apr 5, 2017 | 02:54 PM
JayCee's Avatar
I found this in the manual...Jimmy
Old Apr 5, 2017 | 02:57 PM
Daim's Avatar
Not quite the same part. What I am taking about isn't a sensor. It is a switch. A bimetal strip in a plastic casing...
But it might well be, that the switch was used on earlier models than the sensor shown in fig. 2 in your drawing...
I could see if I can find a temperature at which it activates. If 25° then it is exactly that.
Old Apr 5, 2017 | 03:51 PM
warrjon's Avatar
The switch on the back of the A air cleaner is a bi-metal strip and closes at 75°C its function is to retard ignition at high temperature.
Old Apr 6, 2017 | 01:41 AM
Daim's Avatar
Cheers Warren!
Marelli only?
Old Apr 7, 2017 | 11:20 PM
Doug's Avatar
Marelli only.
I've attached some Marelli info
File Type: pdf
Old Sep 22, 2017 | 03:15 AM
rgp's Avatar
rgp
so what is this arrowed item please
Attached Thumbnails Air temperature switch A bank side air filter box?-100_2226.jpg
Old Sep 23, 2017 | 04:57 AM
rgp's Avatar
rgp
its a soli valve, what its for no idea
Old Sep 23, 2017 | 07:27 AM
JigJag's Avatar
Is that connected to the air pump?
Old Sep 23, 2017 | 05:05 PM
rgp's Avatar
rgp
no, I don't have an air pump as its an 84 uk car. 2 wires and 2 vac pipes though part no
is eac3488
Old Sep 23, 2017 | 05:46 PM
Daim's Avatar
Seems like something that wasn't carried over to an 89.
Old Mar 12, 2019 | 07:09 PM
VancouverXJ6's Avatar
What exactly would that accomplish in normal road conditions? Dumb it down to compensate for a hot climate/engine temp or something?
