all electric
Old Sep 23, 2013 | 01:31 AM
rgp's Avatar
rgp
Default all electric
finished the fan conversion pic 2, but while the rad was moved towards the engine
I noticed a lot of grass cuttings debris in the rad but the condenser was clean, the only way in is over the top of the condenser and under the top rad support, pic.1 should this gap over the condenser be filled with foam? (taken from the front ) looking at that picture I may try to find a trans cooler to fit in the middle of the fans, suspended from the top support.
Old Sep 23, 2013 | 06:28 PM
JagZilla's Avatar
I wouldn't worry about that gap, especially if you have the rad sealed against the top support. I believe in sealing around the radiator with foam, but, there are also members here who have run without foam for years, with no adverse effects.
Old Sep 25, 2013 | 07:28 AM
Scoupe89's Avatar
Clean Good looking Engine!
Let us know how the fans work. My electric tends to run down the battery when hot!
Old Sep 25, 2013 | 12:45 PM
rgp's Avatar
rgp
I had that happen with the air-con fan only in a 1hr very slow moving traffic
jam a couple of years back on a hot sunny day. I changed the battery
box recently to take a larger than standard battery, so fingers crossed on that one, the 2 fans I have fitted are both 80watts.
bdboyle
Nov 6, 2015 02:07 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
magmedia
Sep 28, 2015 09:49 PM
