Alternator dump module wiring
Old Oct 18, 2018 | 07:19 AM
brinny's Avatar
Default Alternator dump module wiring
It’s been a while and my memory is not what it was lol . The wire coming from the load dump module has a couple of wires with round connectors on the end. Can anyone tell me if both these connect to the rear of the alternator or are they earths? Or indeed where they fit to. Many thanks for your help.
Old Dec 2, 2025 | 07:24 AM
bknorwood's Avatar
I'm re-installing my 5.3L after removing it 6 or 7 years ago....I have this same problem. There are two wires (one definitely is connected to the load dump module) that come down the right hand inner wing, both terminating in smallish circular connectors. I *think* both of these go on the smaller terminal on the rear outer edge of the alternator. I understand the purpose of the dump module and saw somewhere in another post/forum that the other wire is alternator excitation.
Is this correct, do both wires go on the alternator?
Thanks,
Brad
1991 Jaguar XJS Coupe, Classic Edition (now with a 5 speed manual transmission!)
Old Dec 2, 2025 | 07:59 AM
Doug's Avatar
These diagrams show the dump module.
One wire goes to ground. According to the diagram they're both black. You'd need to figure out which one so that the diodes are in the right direction.
Old Dec 2, 2025 | 10:33 PM
AZDoug's Avatar
What is the purpose of load dump module?
I have never heard of anything like that, or run across anything like that
Old Dec 2, 2025 | 11:29 PM
Doug's Avatar
It's a protection device but I've never known the theory behind it nor why the XJS needed one when other cars didn't.
Earlier XJSs, like my '88, had an overcharge warning light. Again something I've not seen elsewhere.
Others will chime in.
Old Dec 3, 2025 | 04:39 AM
bknorwood's Avatar
Default Adding a pic!
….which (they say) is worth a thousand words!
”G” marks the load dump ground. The connection that I am asking about is aft of the load dump box, marked “??”
Old Dec 3, 2025 | 06:15 AM
Doug's Avatar
To my eyes it looks it might be brown/black. If so, that's the exciter wire that goes to the alternator together with the dump module wire
Old Dec 3, 2025 | 06:21 AM
bknorwood's Avatar
The alternator load dump system works to mitigate huge voltage spikes that can occur (I've read from 100 - 120VDC! To be fair, these are very short transients, up to 100ms, but still pretty impressive) when the load of charging the battery (or other large load) is suddenly removed. This is done to protect sensitive electronics that would otherwise get fried.
Brad
Old Dec 3, 2025 | 06:22 AM
bknorwood's Avatar
Yes, it IS brown/black.
Thank you, Doug!!
Brad
Old Dec 3, 2025 | 06:40 AM
Greg in France's Avatar
So it acts a bit like a condenser on a points ignition then?
Old Dec 3, 2025 | 09:18 AM
AZDoug's Avatar
Seems like a Lucasism device, to me.
I've seen many otehr cars with alt warning lights, that would illuminate in an undercharge or overcharge condition, but not overcharge per se.
I also see the alternator "seems" to be of a 2 wire variety, rather than three wire, which may ahve something to do with the module, unless the module acts as the third wire.
A typical SI alt I am familiar with has the main power wire, an ignition wire that keeps the regulator inactive during 'off", and a voltage sensing wire that gives a relative voltage from distant source to compare to batt voltage, and adjust output accordingly.
Doug
Old Dec 3, 2025 | 09:56 AM
AZDoug's Avatar
Here is wiring for a typical US alternator and regulator, both external and internal regulation. Note the ext regulated alt has a capacitor
Doug
Old Dec 3, 2025 | 11:48 AM
davchr's Avatar
No, it has zener diodes that will conduct at anything over a specified voltage. So any voltage over the zener's spec will be clamped to ground. They are fast so they will/should get rid of any/most transients and protect electronics on the +12V battery power line. They act as a voltage regulator. It looks like the load dump module is kind of a pricey part, >$200 for a used part. If mine went out I would probably buy two 15V zeners from Digikey for about $.13 each and replace the Jaguar part.
Old Dec 3, 2025 | 02:01 PM
AZDoug's Avatar
So, there is no internal voltage regulator on these Jag alts?
Doug
Old Dec 3, 2025 | 04:10 PM
Doug's Avatar
Doug
They do have a traditional internal voltage regulator.
Old Dec 3, 2025 | 04:17 PM
Doug's Avatar
Doug
The interesting thing is that the Series III V12 sedans, which had the same electrical architecture as the XJS, and were being built concurrently to the XJS, never had the dump module nor the overcharge warning light.
Old Dec 3, 2025 | 05:17 PM
ptjs1's Avatar
And the late 6 Litre ones, such as the one whose alternator I'm trying to resolve, don't show mention of a Load dump Module. Presumably everything managed via the internal regulator?
Paul
Old Dec 3, 2025 | 05:19 PM
ptjs1's Avatar
Duplicate. Apols
Paul
High123bid
XJ40 ( XJ81 )
Dec 20, 2022 10:14 AM
VadimP
Oct 19, 2018 03:03 AM
vettegood
Nov 6, 2014 05:16 AM
gthawk1
Jan 28, 2014 07:07 AM
SleekJag12
May 17, 2013 05:19 AM
