Andy Bracket Installation
Old Jun 3, 2021 | 04:34 PM
DocBottster's Avatar
Default Andy Bracket Installation
Hey Guys,
I just bought a used 5degree Andy bracket for my XJS AJ16. As the seller lost his installation manual I have no clue how to install it.
Can anyone maybe send me his manual via pm?
Thanks in advance and best regards from Hamburg
Hendrik
Old Jun 3, 2021 | 04:38 PM
Vee's Avatar
Vee
Its quite self explanatory.
You’re just swapping out the old, existing bracket with the new one.
Old Jun 3, 2021 | 04:40 PM
Vee's Avatar
Vee
Take the sensor off. Remove the old bracket that it’s attached to.
Place sensor in new bracket, lining up securing bolt holes.
Install using same bolt used to previously secure the sensor.
Old Jun 3, 2021 | 08:50 PM
Mikekeay's Avatar
Default Andy bracket
What’s an Andy Bracket? I’m sitting here feeling a bit thick.
Old Jun 3, 2021 | 09:53 PM
Vee's Avatar
Vee
https://www.jaguarforums.com/forum/x...engines-66536/
Old Jun 3, 2021 | 09:54 PM
Vee's Avatar
Vee
check this out
Old Jun 3, 2021 | 11:19 PM
Mikekeay's Avatar
Many thanks Vee I’m now a little wiser.
I have another query you may be able to answer but not to break this tread I’ll start another.
cheers
mike
Old Jun 4, 2021 | 02:45 PM
Fergolf's Avatar
Is it valid for 3.6 engines too?
Where can you get it? and the price?
Old Jun 4, 2021 | 04:20 PM
Vee's Avatar
Vee
If you go to the link, and read through the posts, you will get the email address for the seller. He can answer your questions regarding if its suitable on the 3.6
Old Jun 4, 2021 | 09:15 PM
stran0020's Avatar
How is the Andy Bracket, Doc? I was thinking of getting one to improve gas mileage
Old Jun 5, 2021 | 08:24 AM
Vee's Avatar
Vee
I haven't really noticed an improvement in gas mileage. The engine just feels less sluggish. For the amount of money and effort involved, I'd absolutely recommend it.
Old Jul 4, 2021 | 12:24 PM
I did not feel a big difference. It was even less powerful in my opinion.
UNTIL I filled the cat up with 102 Octane Aral Ultimate. Now there is a huge difference. Much more responsive, seems to shift earlier, suddenly it’s really close to my V12.
Fuel quality obviously has a big impact if you drive a Andy-bracket. May the specialists here explain why…
Regards from Hamburg
Old Jul 4, 2021 | 01:43 PM
Jagboi64's Avatar
The car has a knock sensitive ignition, so will retard timing to prevent knock. If you are using a higher octane fuel the system cam move to it's mapped value, plus the 5 degrees the bracket adds and it won't be retarding.
From Andy's thread, the ignition system was designed to run on 95 RON (or 90 AKI) fuel, on the engine dyno they brought it to a fully heatsoaked condition under full load and then retarded the timing 3 degrees. very rarely in normal driving will a car ever reach that condition, so you shouldn't need 102 RON fuel to get the benefits of the bracket.
On my XJR the highway mileage increased by about 2 mpg, or decreased by 0.7 L/100km after fitting the bracket.
dskul1
XJ40 ( XJ81 )
Oct 17, 2016 03:08 PM
scarbro2011
Jun 3, 2016 03:50 PM
Vee
Dec 14, 2014 12:12 PM
worrasf
Sep 20, 2014 08:31 AM
aode06
Oct 29, 2013 08:39 AM
