Another exhaust question...
Old Jan 19, 2017 | 12:33 PM
Daim's Avatar
Default Another exhaust question...
Hey guys,
I've decided on what exhaust my car will be getting, and will be starting with the downpipes...
The downpipes are fitted via a compression ring to the manifolds. As they aren't the easiest parts to access when the engine is in place, I wanted to quickly ask: would it be clever to use some exhaust paste/sealer between both parts to make sure that gas tight is gas tight? Not that I have to fiddle around in these areas again...
Or are the gasket rings enough?
Damien
Old Jan 19, 2017 | 12:55 PM
Vee's Avatar
Vee
Not sure what MY you are driving (you really should add a signature line so no one else will ever ask you again), but in my experience, the crush gaskets seem to work well enough. Of course, I can't see how adding some paste would hurt. It would only make for a messier reinstall should you have to get back in there again later in time.
Not the end of the world though.
Old Jan 19, 2017 | 01:25 PM
JagCad's Avatar
Not experienced here. But, in my application, a flat gasket has performed well. Flat and clean manifold against flat and clean "down pipe" surface is leak free sans "goop".
I've never resorted to "Goops" here. Heat and PSI likely to defeat most "Goops", if not all.
Carl
Old Jan 19, 2017 | 01:44 PM
Daim's Avatar
Hey Vee,
My cars are all in my signature... With engine and year!? Odd...
Carl
Okay Carl, I'll do without... Should be okay as is then...
Old Jan 19, 2017 | 02:14 PM
JigJag's Avatar
Permatex makes an exhaust sealant for just such joints. New olives good and tight should not leak, but Mine are. I'm pulling those joints for the third time ( didn't have new olives when I opened it first time ) and they are going to get the goop this FINAL time.
Old Jan 19, 2017 | 02:32 PM
Greg in France's Avatar
As long as you use the actual Jaguar crushable ring gaskets they will never leak. I was advise thus and so far it has been true.
Greg
Old Jan 19, 2017 | 04:15 PM
JigJag's Avatar
Greg, mine are Jag but my previous ones were original to the car and badly degraded. It could be I have a bit of them embedded in the manifold. I'll check for it when they come off.
Old Jan 19, 2017 | 04:26 PM
baxtor's Avatar
Originally Posted by Daim
Hey Vee,
Are you posting from your phone Daim?
Signature seems to be omitted when doing so.
Old Jan 19, 2017 | 05:03 PM
Daim's Avatar
Phone and or tablet... Would explain why...
And this is posted via tablet in full site mode... Signature there... Seems to be the mobile view...
Old Jan 20, 2017 | 01:11 PM
JagCad's Avatar
I would add that each surface be true and clean. And care exercised in the torque down to keep the surfaces absolutely parallel.
In abundance of caution, when making the iron manifold to steel pipe joint in my lump, I used brass nuts, star washers and aluminum anti-seize. No leaks, and so far no need to open the joints. I used the option of flat gaskets over "olive" or as Yanks term them donuts.
Partial goof this AM. Thunder and lightning this morning at about 4. Coco not distressed, but fussed, his way!! Woof, woof!! great lungs and good pipes!!
Got chores done and Coco out and fed his kibble and chopped turkey.
Saw a bit of light. Saddled up quickly. Off to market in the Jeep. Ugh, missed the window, right in to the teeth of the shower. Pet store for Coco rations, market for mine. Imaginative lunch coming up. Canned soup over a slice or two of SF's famed sour dough bread. And, a side of avocado and tomato slices.... A dark brew to wash 'em down!!!
Carl
Old Jan 20, 2017 | 02:45 PM
warrjon's Avatar
Greg's right I replaced the crush gaskets on the down pipes and mine is still leak free there, even after a couple of removal and refits.
