Another XJS :)
Old Jul 31, 2013 | 11:57 PM
smgdata's Avatar
Default Another XJS :)
Just picked up a really rare, 1995 XJS 4.0l coupe 125k and its perfect. goes great with my red 86 xjs. Am i crazy?
three issues, the instruments gauges all work the batt gauge moves around and the others move when somthing turns on/off. the next is, Just sorta fixed the right blower from not on to always on high.. the whole climate system works when it wants but always blows air which is good, and it looks like the front aux fan isnt working other then that its perfect.
Shes a looker.
Attached Thumbnails Another XJS :)-1069168_10151806717042288_47724771_n.jpg
Old Aug 1, 2013 | 01:27 AM
calvindoesntknow's Avatar
looks sharp! good luck to you man
Old Aug 1, 2013 | 03:48 AM
AL NZ's Avatar
Nice car
What is rare about a 95 4 litre? low build numbers?
The revised rear window glass really gives the flying buttress C pillar a lighter look, at least in that colour and from that angle. I like it.
I am on the slow lookout for a facelifted XJS but I want a 6 litre. None for sale in NZ for the past few months..
Old Aug 1, 2013 | 06:15 AM
JTsmks's Avatar
Al I think "rare" refers to the fact that it's a 95 4litre, "coupe".
Old Aug 1, 2013 | 07:38 AM
Spikepaga's Avatar
Very nice car!
The front electric fan is set to come on at like 220 or so. Most of us have modified them to come on with the A/C.
The wandering voltage gauge is going to be either poor connections (disconnect your battery and check your connections at the alternator and firewall) if its not that them it's the ignition switch connector. Which you can eliminate.
Your A/C sounds like the climate control ECU is bad or a potentiometer.
Good luck
Old Aug 1, 2013 | 05:27 PM
smgdata's Avatar
Thanks for the info, Spikepaga,
where is the ignition switch connector?
Its been fun checking out all the differnt things on this, then on my 86
Old Aug 1, 2013 | 08:01 PM
Forcedair1's Avatar
Wonderful facelift coupe! ... and the color is exquisite...
I, too, believe that you may have an intermittent connection to the instrument cluster assembly, and since everything appears to be moving rather randomly, you may be looking at a fretting ground feed to the cluster.
XJR6, pre and post facelift XJS', etc....nice collection.
Cheers!
Old Aug 2, 2013 | 01:36 AM
dsetter's Avatar
That looks excellent. Do they have any more. I need a coupé.
Old Aug 2, 2013 | 08:41 AM
AllanG's Avatar
Congrats! A very attractive car indeed
Cheers,
Allan
Old Aug 3, 2013 | 04:28 AM
Spikepaga's Avatar
Its under your steering wheel. Big dark connector with white wires. Mospeople eliminate the connector and solder the wires together in these.
Rivguy
Dec 4, 2020 07:55 AM
CXJ
Nov 28, 2015 11:41 PM
hoodun
Sep 26, 2015 11:41 PM
alextoevs
Sep 20, 2015 05:21 PM
XJsc-guy
Sep 2, 2015 11:43 AM
