Antenna relay
Old Jul 25, 2015 | 11:10 AM
lordlionheart's Avatar
Default Antenna relay
Hello everyone. I have a 1988 Hess and Eisenhardt XJS. The antenna stopped working and is stuck up. I checked the relay and there is only power on the white and pink wire. No power coming out of the relay. I presume power has to come out of another wire for the relay to work. Also can anyone tell me what each wire does? Thanks in advance
Antenna relay photo
Old Jul 25, 2015 | 01:02 PM
Greg in France's Avatar
The relay is a special one that delays the switching off. unplug it and carefully remove the green cover. Chances are you will find the little contacts inside either fused together or badly burnt. Clean them up with a bit of emery and it should start working again. New relays are still available too.
Greg
Old Jul 25, 2015 | 01:14 PM
Greg
Thanks for the reply. If anyone has answers to the specific questions I had it would also be much appreciated
Old Jul 26, 2015 | 02:01 AM
My Lord,
Please excuse my lack of clarity. The reason the aerial is not coming down is because the two points inside the green relay box are fused together and cannot separate. When they do separate, the aerial will come down. The power in that you have identified is not getting to the motor on the aerial to reverse it so the aerial winds in, because the points inside are not switching it because they cannot separate and thus do the switching. Once the points separate there will be power to a third wire from the relay to the aerial motor!
Greg
Old Jul 26, 2015 | 09:29 AM
HI Greg,
Thanks again. I got a replacement relay yesterday as it was only $6 on ebay. That made the 10 amp in line fuse on the purple wire marked ariel (antenna ) blow. I replaced that with a 9 amp which also blew then a 14 amp which blew the 15 amp under steering wheel fuse. Further investigation pending when I get more fuses
Old Jul 26, 2015 | 09:46 AM
HI Greg,
Maybe a short in the feed from the relay to the aerial? Maybe the aerial internal sort?
Greg
Old Jul 26, 2015 | 04:01 PM
Greg
Weird thing is that now I've replaced the 10 amp fuse on the purple wire the 15 amp main fuse under the steering wheel is blowing. That's the least of my worries after taking the car for a drive today, or trying to. Major coolant leak after just paying for a new water pump and having the radiator rodded
Old Jul 27, 2015 | 05:23 PM
New expansion tank ordered as it turns out that's the latest coolant problem. Still curious why the 15 amp fuse is being blown at the under scuttle main fuse box and yet the 10 amp in line fuse on the purple wire is now remaining intact?!
Old Jul 31, 2015 | 10:58 AM
Pretty sure I've traced the short to the antenna motor. The 15 amp main fuse blows when I connect the plug wire to the antenna motor body. Not sure if the motor can be pulled and repaired or is it a sealed unit? Anyone?
Old Jul 31, 2015 | 12:55 PM
malc4d's Avatar
Might be better to get a new one.
http://www.jagbits.com/jaguarpowerantenna.php
Old Jul 31, 2015 | 01:06 PM
Originally Posted by malc4d
Nearly $400?!?!! Better for who?? That's exactly why I'm looking for a workaround
Old Jul 31, 2015 | 04:58 PM
malc4d's Avatar
And you own an XJS....hmmmm
Old Jul 31, 2015 | 05:10 PM
I'm sure we could go through every thread on this forum and answer 'buy a new one'.............kind of defeats the purpose of the forum
oldjaglover
Dec 25, 2024 04:33 PM
hoodun
Nov 20, 2022 02:35 PM
jagent
Jun 5, 2022 02:18 PM
philwarner
Jan 31, 2016 09:36 AM
