Anyone making fuel injector harnesses
Old Oct 10, 2019 | 12:19 PM
kmarajh's Avatar
Default Anyone making fuel injector harnesses
Hey all, Getting ready to send off my fuel rail and injectors to refurbish on the 90 and figured i'd replace the harness " while im at it" Was looking to see if anyone on here is making these for resale before I bought all the components to do it myself. Please message me with cost and turn around time if you do.
thanks
Old Oct 10, 2019 | 01:41 PM
Greg in France's Avatar
SNG Barratt (a commercial firm and forum supporter) do.
Old Oct 10, 2019 | 01:42 PM
kmarajh's Avatar
yeah I checked them but its been on backorder forever
Old Oct 10, 2019 | 02:17 PM
leo_denmark's Avatar
Call or mail them. Most likely they are producing them on order.
i got mine from a guy on Facebook. Oliver Grimmett. 250 GBP without connector, ie to solder in.
Old Oct 10, 2019 | 02:39 PM
jag-reflex's Avatar
I hunted around and decided to build my own. Got the parts, just waiting for the weather to get lousy enough...
Old Oct 10, 2019 | 03:59 PM
JayJagJay's Avatar
I have to and will rebuild mine using it as a guide myself. Near future...
Old Oct 10, 2019 | 04:09 PM
kmarajh's Avatar
Started looking at parts today and I'm about $200 for wire, angled connectors from fuel tech and high temp loom. Not sure if I'll change the main connector yet as I really don't see the NEED for a weather tight one, these work fine for what they do. Will leave a little extra length in case I have a change of heart later on. Spoke with SNG, they are 12 weeks out on them so I can't wait that long. Can save another $30 if you get the generic EV1 straight connector off Amazon but I was told they need shaving to fit properly.
Old Oct 11, 2019 | 02:51 PM
VancouverXJ6's Avatar
I used jaguar specialties for my harnesses they're made on demand with new oem plugs, he comes on the forum sometimes to talk about v8 conversions.
Old Oct 12, 2019 | 01:31 PM
JayJagJay's Avatar
Is it possible to just.get.plugs...? a savings thing.... Then, build the rest of the harness yourself...?
Old Oct 12, 2019 | 01:34 PM
You can buy everything except the big white rubber socket, that I believe requires a specific machine. Some people remove that bit and buy two 6-prong sockets and just rewire the end connection bit going back to the car.
Old Oct 12, 2019 | 02:31 PM
JayJagJay's Avatar
Understood! Thank you...
I better learn to start thinking MORE outside the box...
Old Oct 12, 2019 | 03:04 PM
FI Harness Rebuild
Relevant link
Old Oct 13, 2019 | 03:00 AM
user 652867429824's Avatar
FI Harness Rebuild
Relevant link
I went this route following the diagram, but also used a piece of plywood covered with poster board,. Then I mounted my old harness striped of the insulation (or what was left) and used it
as a pattern.
Old Oct 13, 2019 | 06:22 AM
Robert Laughton's Avatar
I thinb this gent sells them
https://www.jaguarfuelinjectorservice.com/
Rob
Old Oct 13, 2019 | 06:42 AM
Rob
No longer I am afraid.
Old Oct 13, 2019 | 09:14 AM
Doug's Avatar
Just a few random, quick remarks.....
A couple of the pink/black wires can be eliminated, if desired. You don't really need all four.
High grade, high temp wire is readily available (I forget the alpha designation at the moment) and not horribly expensive so there's no strong reason not to use it. But, in all honesty, I think the most important improvement in durability comes from re-routing the harness so that elevated away from the engine. Jaguar anchored the harness right onto the engine, ensuring that the harness is well baked. If, for whatever reason, a person wanted to use standard grade automotive wire, he could probably get away with it if the harness was re-routed.
There's almost no end to the variety of heat-shield wraps and tapes available. It's truly a 'tyranny of choice' situation. On my latest harness I used something like this and then wrapped the whole shebang with Tesa black tape (Note: Tesa makes a variety of tapes, not all are rated for high heat, so be careful)
https://www.jegs.com/i/Vibrant-Perfo...25830/10002/-1
Amazon Amazon
On another harness I used self emulsifying tape and then covered with the back tape. Worked fine.
https://www.heatshieldproducts.com/hp-racers-tape
You can buy pre-made injector connectors with 'pigtails' for $2.00-$10.00 each. I've had no problems with the less expensive offerings....and found out that, in some cases, the more expensive offerings were the exact same part but merely higher prices! Just Google "Bosch Injector Connector"
If you can live without the 2" long rubber boot at the injector connector you can save money, as I've never found those for less than about $6.00 each.....adding $72.00 to the project! I use a couple layers of shrink tubing instead
Old Oct 13, 2019 | 10:06 AM
JaguarSpecialties's Avatar
Former Sponsor
Default Jag wiring..
Guys- just a quick note. We have a supplier that can make pretty much any of the XJS harnesses including the Marelli ignition harness. All of the harnesses are made with modern wire, new connectors, etc.,. He makes all of the special harnesses we use for the XJ6 and XJS engine conversions and has for years. All of those plug into the chassis just like the originals. He has the capability to mold the rubber-ish connectors that Jaguar used on nearly all of its wiring until the early 90's,.... BTW, he also has harness braiding capability as well so the original style fabric covering is available if wanted/needed.
Just as an aside, he also does rework and has completed several full 92 engine harness rebuilds for a our customers. In case you weren't aware Jaguar used a terrible quality wire in the 92 harnesses, so bad in fact that the wiring just fell apart (insulation turned to dust) leaving nothing to even repair. He took the remnants and reworked the entire unit, just like original which then plugged right back into the car... And of course the modern wire and components should last forever essentially... Attached is a pic of the last 92 harness he did, all strung up on the board as he works, and a close up of the finished product.
Our guy has been doing this for years- if you need something, send me a PM and I would be happy to look into it.
Old Oct 13, 2019 | 03:26 PM
anyoldiron's Avatar
Banned
Old Oct 14, 2019 | 12:00 AM
Former Sponsor
Default Hmmmm
****, like sexy harnesses??
Originally Posted by anyoldiron
Old Oct 14, 2019 | 03:03 PM
scottpeterd's Avatar
I am about to start on this, for my 1992 V12
Where under the hood is the 8 pin connector that connects the FI harness to the FI loom running to the rear of the car?
