Auto gearbox humming
Hi all,
my 89 5.3 gearbox makes a humming noise on the overrun. As the car has had a lot of refurbishment work done I'm keen to eliminate any basic things before I start major surgery. The cable was adjusted and I wonder if this could be something to do with it. Will double check the fluid level as it's been changed not long ago. Is there anything else it could be? Drives fine. Many thanks in advance
If it drives ok, you may not have a problem! Are you 100% sure it's the transmission? The rear differential can have a humming sound under coast if the backlash isn't quite right. The sound will go away under power and come back when coasting. Might be a U joint too.
MK2
Nov 27, 2016 02:15 PM
hermand
Jul 22, 2016 09:45 AM
Gavhowe
Feb 28, 2015 10:43 AM
