Auto gearbox humming
Old Aug 13, 2023 | 07:16 PM
brinny's Avatar
Default Auto gearbox humming
Hi all,
my 89 5.3 gearbox makes a humming noise on the overrun. As the car has had a lot of refurbishment work done I'm keen to eliminate any basic things before I start major surgery. The cable was adjusted and I wonder if this could be something to do with it. Will double check the fluid level as it's been changed not long ago. Is there anything else it could be? Drives fine. Many thanks in advance
Old Aug 13, 2023 | 07:37 PM
Jagboi64's Avatar
What cable? The shift points on the TH400 are controlled by vacuum. If you mean the shifter cable, that will have no effect.
Old Aug 13, 2023 | 07:55 PM
brinny's Avatar
Ok thanks that rules the cable out. I feel its something simple but not sure what to check. Only happens on deceleration.
Old Aug 13, 2023 | 08:20 PM
Jagboi64's Avatar
Probably normal, as you are probably hearing the one way clutches (or sometimes called a sprag) inside. I don't have a car with a TH400 anymore to go have a listen.
Old Aug 14, 2023 | 11:42 AM
brinny's Avatar
Just dipped the trans fluid and it looks a bit high , would this have any effect do you think?
Old Aug 14, 2023 | 12:13 PM
Jagboi64's Avatar
A little high is probably fine. Was the fluid hot ( at least 15 miles of driving), engine running and in park when you checked it?
Old Aug 14, 2023 | 12:42 PM
brinny's Avatar
No. I checked it cold.
Old Aug 14, 2023 | 12:45 PM
Jagboi64's Avatar
I think there is a cold and hot mark on the stick isn't there? Hot is considered more accurate.
Old Aug 14, 2023 | 12:59 PM
brinny's Avatar
I will check it again hot , probably at the weekend. Do you think this ayup be the cause of the problem?
Old Aug 14, 2023 | 01:08 PM
Jagboi64's Avatar
If it drives ok, you may not have a problem! Are you 100% sure it's the transmission? The rear differential can have a humming sound under coast if the backlash isn't quite right. The sound will go away under power and come back when coasting. Might be a U joint too.
Robsovereign3.0
Apr 30, 2021 12:43 AM
SayersNeil
Sep 22, 2020 03:31 AM
MK2
Nov 27, 2016 02:15 PM
hermand
Jul 22, 2016 09:45 AM
Gavhowe
Feb 28, 2015 10:43 AM
