Best gas mileage ever returned from a tank of gas or on a long trip?
Old Aug 26, 2014 | 08:17 AM
75Gremlin's Avatar
Default Best gas mileage ever returned from a tank of gas or on a long trip?
Just curious what the best miles per gallon, mpg, you got. Also post your Average miles per gallon if you want.
In your reply, please post:
US or Imperial Gallons
Year model
V12 or 6 cylinder
Manual or Automatic transmission
Any modifications you made to your car which may have changed your fuel mileage. For example, changing the final drive ratio.
Old Aug 26, 2014 | 09:13 AM
Doug's Avatar
1988 XJS Coupe 5.3 V12
The *very best* highway mileage I ever got was 23 mpg. That was a 200 mile or so trip where I was forced to stay close to 60 mph.
More typically I got 18-21 mpg on the highway.
USA gallons, by the way. You know, the real ones. Not those silly inflated imperial type
Old Aug 26, 2014 | 09:54 AM
Japthug's Avatar
23mpg!? That's too good!
Mine is '92 5.3L V12, facelift, 17mpg(US) after 1300km travel is my best. Maybe I am not patient enough :P
Old Aug 26, 2014 | 10:26 AM
dstary's Avatar
16.16L/100km for me over 1900km of largely just commuting. And those are imperial kilometres and litres... Or are they US? I get confused.
I'll caveat that though, as my car has had the diff ratio changed, which causes everything to under read (speedo, odo, trip computer). So based on my actual kilometres done I'd say I could probably drop that figure by around 10% down to 14.5L/100km - not bad for a thirsty old beast, but the 5-speed conversion is undoubtedly saving me a few litres. Now if I could only resist hearing that incredible sound I might be able to get it down to Prius levels!
(Based on some quick googling, 14.5L/100km works out at 16.2mpg or 19.5mpg depending on how big you like your gallons)
Old Aug 26, 2014 | 11:09 AM
Vee's Avatar
Vee
26 mpg on the AJ16.
All highway.
Old Aug 26, 2014 | 12:16 PM
Daim's Avatar
On the trip from Britain to germany: 13.6l/100km
V12 noncat automatic
Old Aug 26, 2014 | 02:21 PM
Tyran66's Avatar
16mpg for me. 85 5.3 V12.
Old Aug 26, 2014 | 02:37 PM
Mkii250's Avatar
24.5 US mpg in my 4.0L 5-speed, averaged over two thousand miles last summer. No trips over two hours of two-lane black top.
Old Aug 27, 2014 | 08:02 AM
sidescrollin's Avatar
I used to get 18-21mpg around town when I lived near atlanta because so much of the road was 55mph, which is a good speed for the XJS with few enough lights.
Now I live in tallahassee with 4 million traffic lights and the speed limit is typically 35mph, so I hover around 12. Last time I counted it was 9, but I was having some fun.
I still spend less in gas because everything is closer together though.
I would be super interested in seeing the return on a 6 speed in a v12. One of the setups from driven man I saw once put 6th gear at 90mph at 1500rpm!
Old Aug 27, 2014 | 08:28 AM
'85 Coupe V12 5.3
Larger throttle discs, 16CU ECU, NO cats, NO emission junk, cold air intakes, 2 1/4" exhaust ALL the way to the rear tips.
11.2l/100km (25+MPG Imperial) for the last round Australia drive which took over 12 months and 20000kms approx. LOTS of flat out running, by that I mean 5500rpm for hours on end, then dirt/mud/rain the next day and down to 50/60KPH most of that day. So a good mix I think. Air con on for 90% of the trip. Car fully loaded, as I am yet to find a wife that travels LIGHT, damn.
Around where I live and at 50KPH speed limited, about 15+l/100kms (18MPG Imperial).
1976 PreHE S2 V12 5.3 (Sir Arthur), stock as a rock, has the fuel gauge moving faster than the tacho no matter how you drive it. Never worked it out, never saw any need to scare myself more.
Old Aug 29, 2014 | 11:26 AM
NtAFord's Avatar
US or Imperial Gallons- US Gallons
Year model - 1989 XJS
V12 or 6 cylinder- 5.3 Liter V-12 about to probably be bored out bigger due to rod knock
Manual or Automatic transmission- T400 Automatic
Just on city driving I was quite surprised on the mileage I just calculated. Came out to about 12.7 MPG
Old Sep 1, 2014 | 11:43 AM
Ezrider's Avatar
when i bought my xjs i drove it about 1300 miles home. my best tank was 26mpg, worst 23mpg. other shorter highway trips have been in that range as well. mixed driving is typically just under 20. all city driving with playing a bit closer to 15.
1993 xjs convt. 4.0L auto.
Old Sep 2, 2014 | 05:26 PM
chriskindbooks's Avatar
My best with 1992 XJS V12 is 22.3 miles per Canadian Gallon stock air intake. I has seen where it can be increased by up to four miles per gallon if one eliminated the standard tubs and went to a wider air intake and clean filters. I plan on doing that for next summer once I decide the pipe routing.
Old Sep 2, 2014 | 10:37 PM
hankspond's Avatar
Default 1996 XJS 4.0l
Best gas mileage has been cruising the back roads in southern Utah
50 to 55 mph at 24 miles per gallon.
Speed limits in southern Utah on freeways is 85 mph.
Cruising at 90 mph mpg drops to 16 mpg.
Old Sep 22, 2014 | 11:04 PM
gregh's Avatar
Default Mileage
'89 XJS w/5.3V-12, currently 102,000 km
-Just got back from 1200 km weekend run, 21.9 av miles/IMP gal. This is very close to my overall mileage, have seen 22.4mpg, but that was running approx. 85km/hr only
I burn Hi-Test (92oct), 3 out of 4 tank fulls.
Old Sep 22, 2014 | 11:32 PM
RonaldP's Avatar
95 4.0 coupe AJ16 automatic
Best highway on two 500 mile trips 21.5
Best in town commute average about 15-16, unless it's bumper to bumper then it drops to 12-13.
But I am a "little" agressive
Old Sep 23, 2014 | 07:31 AM
Vtjaguarlover's Avatar
1992 XJS 5.3 v12
The very best mileage was on 2000 mile trip on highway
18.4 MPG US
Jeff
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
alpecsa
Sep 7, 2015 11:55 AM
giandanielxk8
Sep 6, 2015 07:21 PM
