Bosch Injectors 0280150035 vs. 0280150023
Old Dec 27, 2021 | 08:38 PM
Andreas Schmieg's Avatar
Default Bosch Injectors 0280150035 vs. 0280150023
I just cleaned up my parts storage, ordered clear organizer boxes from Amazon, and sorted all my pre-HE injectors.
I found all 30 of my Bosch 0280150035 injectors as I had hoped for. So I think I should have enough of those until 2050. :-)
But I also found a dozen neatly packaged Bosch 0280150023 injectors with no recollection where I got them from.
Does anyone know when they used Bosch 0280150023 injectors in the XJ-S? Google is all over the place.
Thanks,
Andy
P.S.: Ignore the brown ones. Those are a separate mystery.
Old Dec 27, 2021 | 09:39 PM
alabbasi's Avatar
Are those the green injectors? they were used on Pre HE cars so any Jaguar from 1975-1980 that has a V12
Also used on the Mercedes W114 250CE and 280E and CE.
Old Dec 27, 2021 | 09:44 PM
Both, 035 and 023 are dark green. Just not sure when the 023s came into the picture. In 1975 they installed 035s.
Old Dec 27, 2021 | 09:53 PM
alabbasi's Avatar
The parts probably interchange. Bosch does that a lot. The ones I have are 035's, they were removed from my 71 Mercedes Benz 250CE. I'll check what's on my 75 V12 next time I head out there.
Old Dec 28, 2021 | 05:06 AM
ptjs1's Avatar
Andy,
Are the numbers stamped on the injectors? I have all of the injectors out of my 79 pre-HE and will be with the car in next few days. If you tell me how to identify them, I'll check mine for you.
Paul
Old Dec 28, 2021 | 07:00 AM
Doug's Avatar
If all else fails give a shout to David:
https://www.jaguarfuelinjectorservice.com/
He's likely seen more Jag injectors than anyone one earth!
Old Feb 10, 2026 | 03:57 AM
mcging's Avatar
Hi Andy (and all),
I know this is a really old post, but on the off chance anyone is still following or happens to read this later I thought I’d reply.
I’m currently restoring a 1971 Mercedes 250 CE (M114, D-Jetronic) and discovered that my car had the wrong injectors fitted when I bought it (0280150036), which sent me down the Bosch D-Jet rabbit hole.
From what I’ve been able to gather, the 0280150023 injectors weren’t factory-fitted to the 250ce,
If anyone here happens to have 0280150023 injectors sitting unused and would consider a swap (for 0280150036) or sale , I’d be very interested.
Thanks in advance.
Best regards,
Damion
Mykk
Oct 14, 2020 10:09 PM
Itismejoshy
May 21, 2019 12:18 PM
newbee
Sep 20, 2017 01:58 PM
M90power
Mar 24, 2012 08:35 PM
