Brake Reservoir Hose Replacement
Old Jul 18, 2015 | 01:20 PM
Greddyoro's Avatar
Default Brake Reservoir Hose Replacement
On the early XJS cars, the remote brake fluid reservoir feeds the master cylinder via 2 rubber lines.
Now, any time I ask the old parts guys, they instruct me on how I can't use hose for brake fluid, you can't repair that with that, etc. After I've explained why I need it, they never have a safe answer; it's always a guess.
Age is not kind to rubber, so they need to be replaced. What have you used to replace those two lines? I would have to think a neoprene hose would suffice? Or something like fuel injection or power steering cooler hose?
Old Jul 18, 2015 | 05:25 PM
Bc xj's Avatar
The hose between the reservoir and master cylinder is not hi pressure. I used braided hoses for my car
Old Jul 22, 2015 | 08:24 PM
Dleit53's Avatar
I used high pressure fuel hose on mine, it has been on there about a year, so far, so good.
Old Jul 22, 2015 | 10:09 PM
Typhoon's Avatar
You can buy a hose for this purpose at any older Volkswagen specialist, or any number of online stores. It's basically a thick silicone hose with a cloth over braid.
Old Jul 25, 2015 | 09:08 AM
Greg in France's Avatar
EPDM rubber is the right stuff to resist brake fluid in the feed from the reservoir to the master cylinder: eg
6mm ID 1/4 EPDM Smooth Rubber Tubing Coolant Radiator Hose Brake Fluid Tube Pipe | eBay
Greg
Old Jul 25, 2015 | 09:30 AM
rgp's Avatar
rgp
I got the correct elbow from growler parts
GROWLER PARTS - XJS
quite reasonable priced some of their parts
JarodL
Mar 7, 2024 01:39 AM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
laserguy
Sep 3, 2015 02:02 PM
XJsc-guy
Sep 2, 2015 11:43 AM
