Bulb replacement
Old Feb 15, 2014 | 09:09 PM
YycXJS's Avatar
Default Bulb replacement
Any idea how to get into this light (XJS 2+2 rear interior) to change the bulb?
Old Feb 16, 2014 | 03:23 AM
rgp's Avatar
rgp
if its the same as the centre fhc light it just pulls out (from one sides) and the bulb in the back, easy
Old Feb 16, 2014 | 09:58 AM
superchargedtr6's Avatar
That is exactly correct. The whole assembly will pull right out. Don't be surprised if it isn't the bulb however. These lights get really hot when left on, and the plastic actually deforms, even breaks, and you will find the bulb loose inside the fixture. I have repaired both of mine with a little patience, ingenuity. They are a little pricey used, no idea what they might be new, if available.
Old Feb 16, 2014 | 10:29 AM
YycXJS's Avatar
I seem to be able to get one side to pull it and the other side binds. So one end ends up half pulled out and the other end is still pretty much flush. I can't figure out what I'm doing wrong.
Old Feb 17, 2014 | 06:30 AM
There is a part of the fixture that protrudes just enough to cause what you are describing. When you get the one end pulled out, just tug on it in that direction while pulling out on it. Its not that hard to just pull the whole panel if you are that uncomfortable with pulling on it. That way, you could get a good look at the back side, and see what you are pulling on. There is a metal bracket that is pushed into the hole and the light presses into it. It becomes pretty obvious once out.
Old Feb 17, 2014 | 11:04 AM
dsetter's Avatar
Good to change the bulbs to LED as they do not get hot.
Old Feb 17, 2014 | 12:05 PM
Vee's Avatar
Vee
If not for the terrible bluish light quality.
Believe me, I want to go LED, the light is just too cold.
Old Feb 17, 2014 | 01:21 PM
RonaldP's Avatar
Look for a replacement bulb on Festoon Base Bulbs | LED Car Bulbs | Super Bright LEDs
they have white.
Old Feb 17, 2014 | 03:36 PM
sidescrollin's Avatar
be really careful, I didn't know how these were constructed when I changed my interior to LED and lost the ball bearing as the spring popped out during initial removal
Old Feb 18, 2014 | 10:24 AM
Vee's Avatar
Vee
they have white.
I'm aware of the bulbs they offer, I have used them before.
The lighting is more cold, and bluish that the warm, yellowish light you get from a standard bulb.
Some people don't mind, I do. I think it affects what the car looks like on the inside, alot. The regular bulbs will last long enough once you change it.
99xk8guy
Sep 29, 2025 10:51 PM
Forcedair1
Sep 8, 2025 01:57 PM
RoyLittle0
May 25, 2023 02:38 AM
afterburner1
Dec 16, 2015 12:12 AM
KarimPA
Sep 3, 2015 07:32 PM
