Bulb Warning Light Won't Go Out!
Old May 6, 2019 | 01:30 PM
orangeblossom's Avatar
Default Bulb Warning Light Won't Go Out!
Hi Guys
The Bulb Warning Light on 50 Shades my Grey XJS will not go out, even though everything was ok before I got her packed away in the Garage for the Winter
Checked all the Lights, everything is OK except for this little Electrical Gremlin
Any Ideas?
Bulb Warning Light won't go out
Old May 6, 2019 | 01:52 PM
macdoesit's Avatar
Banned
Mine does the same thing sometimes, Pull up on the emergency brake lever, when you think it is all the way up jerk on it some more, then push the button and force it down quick as you can. The reason I said to get aggressive with it, I did normal a few times and did not work, got pissed pulled it up fast and hard and pushed back down fast and hard and light goes out.
If light is on and I do it normal light will not go out. It works for me.
Old May 6, 2019 | 02:21 PM
Hi Mac
Cheers!
I will give that a try Tomorrow and let you know what happens
Old May 6, 2019 | 02:48 PM
RonaldP's Avatar
Did you replace any of your lights with LED?
Old May 7, 2019 | 01:24 AM
Greg in France's Avatar
Originally Posted by orangeblossom
Hi Mac
Cheers!
The bulb failure light can only be triggered by the handbrake lever if you have your foot on the brake as well. This is a test mode for the BFL. The BF module is a bimetal strip and they do get weaker/jam etc etc. or a poor connector in the light itself can do it, as not enough current flows to heat the bimetal. Drive it for a bit and see if it goes out, after that, post again...
Greg
Old May 7, 2019 | 03:56 PM
warrjon's Avatar
There are 5 bulb failure units.2 on the component panel next to the aux fuse panel, 2 in the boot on each side and the brake light failure unit under the centre console.
You can diagnose it to a single unit by removing the WS wire one at a time and see if the warning light goes out. The brake light failure unit under the console is the WL wire.
If the cruise control works then the brake switches are ok.
Old May 7, 2019 | 05:27 PM
Mac@Greg@Ronald@Warrjon (Thank You For all those suggestions Guys)
Hi Warrjon@Robman25
Well done Guys and Thanks to you both I've finally tracked the Fault down to a blown Festoon Bulb in One of the Number Plate Lights
New Bulb in and Fault Light Out!
Old May 7, 2019 | 06:09 PM
warrjon's Avatar
Damn the bulb failure unit actually works
Old Dec 31, 2019 | 10:20 AM
bknorwood's Avatar
Sorry to be dense, but what are the "WS" and "WL" wires? I'm working on tracking down a bulb failure indication too.
Thanks,
Brad
Old Dec 31, 2019 | 11:31 AM
JayJagJay's Avatar
Thanks,
Brad
Hey Brad... I thought this might be the easiest way... I believe those are the color codes for the wires to the units you're chasing... If you Google wire color codes for the XJS you'll come up with lots of resources and explanations...
Old Jan 1, 2020 | 11:44 AM
bknorwood's Avatar
Thanks - I wondered if those were color designations. But the reason I was skeptical of my supposition remains unanswered by the table. “WL” would appear to translate to “a light white color”. So, assuming that doesn’t mean a cream-colored wore with a white stripe, is it just referring to a solid white wire w/no stripe?
Old Jan 1, 2020 | 12:16 PM
Doug's Avatar
A solid white wire would simply be "W"
I suspect "WL" is a typo or misprint
When "L" is used it is placed before the color identifier, for example....
"G" is green; "LG" is light geen
"U" is blue; "LU" is light blue
Old Jan 1, 2020 | 02:28 PM
JayJagJay's Avatar
Allllll,,,,Toooooo,,,,Welllllll... pita.sometimes...
I guess I'd rather be with them than without
Old Jan 2, 2020 | 04:02 AM
warrjon's Avatar
Sorry WL was a typo I couldn't fix, then I forgot about it until now, it should be LGK, my appologies
Old Jan 2, 2020 | 04:15 AM
Timeisrelative's Avatar
Mine comes on for a few seconds at every startup. It's annoying, but as with yours all of my bulbs are fine. I figure as long as it goes out I won't loose sleep over it. If it didn't, it would drive me crazy lol 😁
Old Jan 2, 2020 | 06:41 AM
That is part of the (intended, designed-in) self-test procedure. One of Doug's "features"!
EZDriver
May 20, 2020 02:43 AM
jomo
Nov 15, 2016 03:30 PM
cybercg
Sep 17, 2012 04:29 PM
