Bumper removal
Old Jun 18, 2016 | 07:56 PM
Dymaxxion's Avatar
Default Bumper removal
Hello all! I'm trying to pull the front bumper from my '83, and the two bolts holding the impact bar to the gas shocks are stuck on there pretty well. Is there any trick to getting them out through the top of the bar? Or do I actually have to remove the shocks with the bar? thanks so much in advance.
Old Jun 18, 2016 | 09:22 PM
baxtor's Avatar
No energy absorbing on my xjrs but as far as l know you should be able to remove the nuts on the inner end of the struts and slide them out of their housings along with bumper complete.
Old Jun 18, 2016 | 10:33 PM
Dymaxxion's Avatar
I didn't think I could get a socket back far enough. I'll give it a shot in the morning! thanks!
Old Jun 19, 2016 | 03:12 AM
Greg in France's Avatar
The absorbers are mounted in a tube in the chassis about 6 inches long. Like Baxtor my car does not have the absorbers, but the tube can be clearly seen in the attached photo LHS of shot. Access to the back of the tube is needed, and this will need the undertray to be removed, at least.
It might be easier to cut the fixings off that attach the absorber to the bumper bracket, if you can get to them. good luck
Greg
TPBachur
Jul 30, 2016 07:33 AM
bigdhenderson
May 4, 2016 06:33 PM
Gerard Radimaker
Apr 18, 2016 10:25 AM
al_roethlisberger
Apr 9, 2016 03:50 AM
Hank03
Mar 30, 2016 04:10 PM
