Carpets
Old Jun 15, 2020 | 03:16 PM
brinny's Avatar
Default Carpets
I received my carpets from Aldridge’s today. There are a lot of parts and it looks very complicated. Anybody fitted a full set and got any advice?
Old Jun 16, 2020 | 01:07 AM
Greg in France's Avatar
Brinny
I looks complicated because of the bits for the sills which have to be glued on, and as I seem to remember so do the tunnel and rear floor (at least on the coupe). Also there are holes for the seat belts anchorages, hand brake, etc etc.
I Would start by just placing them dry on the floor until you have all the bits properly fitting like a jigsaw, then start gluing in the "lowest" ones. The overmats just sit on top of the basic carpet.
Do you have the sound deadening from your originals? If not you do need some, but I would not glue it down until you have all the carpet pieces understood; then glue the deadening, then the carpets.
Old Jun 16, 2020 | 01:18 AM
brinny's Avatar
Good advice Greg thanks. I have dynamat down, will it need the sound deadening on top still?
Old Jun 16, 2020 | 01:50 AM
ptjs1's Avatar
Brinny,
I would definitely run the ssound deadening foam pads in the footwells as they fill a large gap to make the carpets sit level.
Good luck
Paul
Old Jun 16, 2020 | 02:38 AM
brinny's Avatar
Right will do thanks. Does the sound deadening need glueing down too?
Old Jun 16, 2020 | 02:58 AM
yes
Old Jun 16, 2020 | 09:44 AM
Rescue119's Avatar
I've removed my driver side stuff so far. If I plan on not using OEM style carpet can those 2 brackets where the carpet clips into (near the pedals) can they be cut off flush?
Old Jun 16, 2020 | 11:44 AM
brinny's Avatar
Mine went when the new floorpans were fitted
Hafrod
Feb 12, 2016 09:46 AM
reichstall
Dec 20, 2015 06:41 PM
Fixer88
XJ40 ( XJ81 )
Sep 20, 2012 09:21 PM
goldencharriot
Sep 15, 2009 11:41 AM
