Castor measurement & shims
Old Apr 16, 2022 | 11:29 AM
SayersNeil's Avatar
Default Castor measurement & shims
Hi all,
Anybody able to guide as to how to correctly measure current Front Castor angle on my car,
Next question is, regarding shims, currently there are 2 shims each side, however I query what is "standard" I have seen written that 6 shims in total with some cars having all 6 on one side to achieve 3.5 Degrees positive camber is normal.
As mentioned my car only has 4 in total, The steering feels awfully light, twitchy and will not return to centre, Camber and Toe settings are now correct.
Anybody able to help ??
Old Apr 16, 2022 | 11:56 AM
Doug's Avatar
Six shims is what I've typically seen over the years. But the older parts catalogs show 8 in the "Number Required" column.
Also, there are 'thick' and 'thin' versions of the shim, which may enter into the discussion.
Old Apr 16, 2022 | 12:01 PM
Doug's Avatar
More caster increases the tendency to return to center and increases steering response/feel......which might be interpreted as 'twitchy'
Lack of self-centering might be a fault elsewhere. Steering rack, ball joints, tie rods.
Old Apr 16, 2022 | 12:04 PM
Greg in France's Avatar
Two shims each side of the wishbone arm/balljoint interface (4 per side, 8 per car) is standard. To increase caster, move shims FROM the back TO the front.
Your steering fault sounds like a rack/rack bushes/balljoint problem to me.
Old Apr 16, 2022 | 03:04 PM
Vee's Avatar
Vee
I’m not sure I know what model year and engine you have.
I do not have my service manual, but I believe moving 1.6mm shims from front to back, they are never to be removed, makes a 1/4 degree adjustment.
Old Apr 17, 2022 | 01:26 AM
I think that is the data for the camber change caused by removing/adding a shim, Vee.
Mpowerr
Apr 7, 2024 08:36 AM
sunchip
Apr 4, 2022 12:47 AM
jagtoes
Apr 8, 2016 06:14 PM
DaveInVA
Aug 19, 2014 02:10 PM
Vee
Dec 15, 2012 09:25 AM
