CatCooler Radiators
Old Mar 27, 2015 | 10:07 PM
Broken_Spanners's Avatar
Default CatCooler Radiators
Hello,
The old Concour queen needs a dose of reality and I'm going through and re-doing the cooling system. The OE rad has never been touched, the car runs "cool", but I get an occational nudge on the upper "N", so gutted she gets!
Originality aside, I've had a great luck with the Ron Davis stuff in some of my other Jags, and saw the "Super Duty Catcooler" (still not a one-pass), which looks interesting and the price is good too.
Anyone used these and / or have other suggestions?
I suppose I will go with 190 stats, but lower the aux switch temp. Don't really want to add coolant filters, but thoughts there too.
Thanks all..
Jeff
Old Mar 28, 2015 | 11:44 PM
Never mind, after digging more, answered my own question, going Wizard avoiding other.
Old Mar 29, 2015 | 08:00 AM
86jag's Avatar
I have a CatCooler Radiator. At one time I also had my hands on the BeCool Radiator. An added bonus of the aluminum radiator is that it is ~20lbs lighter. When I had all 3 I measured the weight and size of all 3 radiators, and the BeCool and CatCooler(Wizard) were about the same weight, and all where about same thickness, but the number of fins varied. I will have to find my documentation on it.
The CatCooler is top notch quality. I believe you made a great choice. I decide on the CatCooler so I didn't have to create custom hoses to use the BeCool.
Old Mar 29, 2015 | 11:39 PM
What I can't tell is if the Wizard has the push-on hose fittings?
Also, did you switch to electric fans or stick with OE?
Thanks for the feedback!
Jeff
Old Mar 30, 2015 | 07:34 AM
Doug's Avatar
Originally Posted by Broken_Spanners
Hello,
Spend money as you wish, of course, but IMHO you might be over-reacting to an ".....occational nudge on the upper "N"...." .
A CatCooler radiator sounds expensive to me.
Old Mar 30, 2015 | 07:04 PM
86jag's Avatar
Jeff
I purchased dual electric fans, however I have not yet installed the radiator or the fans yet. The wizard/CatCooler has AN- Fitting on the radiator which you can purchase whatever style of connection you need. It comes with a fitting to work with the HE style screw connection. Due to the hoses not being cheap I had my local hydraulic shop make me some angled fitting that I can connect to AN Fittings.
Old Mar 30, 2015 | 07:16 PM
Doug - The cooling system in my car has never been gone through / the radiator is likely plugged in some capacity as my occational nudge is not ambient nor driving style dependant, which tells me its time to R&R the radiator anyways and the Wizard is cheaper than OEM / I have not had good luck with re-cores in my area.
I'm effectively taking the front of the motor apart anyways, new pump, belts, t-stats and replacing the alternator, as she's barely putting out 12 volts.
No time like the present and then she's good for another chunk..
Jeff
Old Mar 30, 2015 | 07:17 PM
Thanks, Wizard noted that both fittings are supplied with their unit, perfection..
Jeff
hoodun
Feb 20, 2023 05:52 AM
Mac Allan
Jul 20, 2020 05:46 PM
wynlaidig
Sep 2, 2016 08:08 AM
Seth
Nov 1, 2015 12:17 PM
andyXJR
Sep 29, 2015 04:29 PM
