Check engine light intermittent when I press brake pedal
Old Dec 11, 2018 | 11:24 AM
XJSHouston's Avatar
Default Check engine light intermittent when I press brake pedal
Anyone come across this before? 95 XJS 4.0 2+2 90K. Runs like a Swiss watch. Plenty of power. Seems to happen during cooler temps. Cruising along, press brake pedal for stop sign, light, etc., check engine light comes on for a few seconds then off. Intermittent. Sometimes doesn't do it. My local Jag guru has never seen or heard of it. Anybody?
Old Dec 11, 2018 | 01:54 PM
mghirsch's Avatar
Don't know for sure, but it might be a poor ground in the instrument panel. Run an extra ground wire to the chassis and see what happens.
Old Dec 11, 2018 | 02:27 PM
orangeblossom's Avatar
Hi XJS Houston
Have you Checked the level of the Brake Fluid, as it could be the Low Level Brake Fluid Warning Light that's coming on
Old Dec 11, 2018 | 02:38 PM
carsnplanes's Avatar
Is it actually when you press the brake pedal or are you coincidentally pressing the brake pedal just as you decelerate. Does it come on when you decelerate but not press the brake brake? Does it come on when you are just sitting and press the brake?
Old Dec 11, 2018 | 03:17 PM
XJSHouston's Avatar
It's just when I press the brake pedal whether decelerating or simply coming to a stop. Does not come on while sitting still with depressed brake. Only when slowing down and only for a couple of seconds at a time.
Also, to answer Orangeblossom below, when it first happened, I thought immediately it must be the brake warning light coming on, but as soon as it happened again, noticed it was definitely the check engine light. Not the brake light.
Old Dec 11, 2018 | 03:56 PM
Mac Allan's Avatar
If the Engine Light actually comes on, the ECU should store a pending code. Finding out what that pending code is might help you pinpoint the issue.
Old Dec 12, 2018 | 01:59 AM
Greg in France's Avatar
This sounds like a classic earthing or cluster flexible problem to me.
powerhouse
Jul 26, 2022 08:24 PM
JaguarRookie
Jan 25, 2018 05:41 AM
jfleming
XJ40 ( XJ81 )
Mar 2, 2016 01:46 AM
5speedusa
Apr 19, 2014 09:02 AM
