1999 XJR. Intermittent RP light, and hard check engine light.
Old Jan 24, 2018 | 12:55 PM
JaguarRookie's Avatar
Default 1999 XJR. Intermittent RP light, and hard check engine light.
Hi Guys,
It seems that this is a common XJ affliction. The car runs fine, but the CE light stays on, and RP pops on, usually after the car is stopped and well heated up. It stays on for a minute or less, then pops off.
I've cleaned the MAF sensor, but am still getting P111 codes, as well asPO171, PO174 (lean, both banks). I've ordered a new breather hose as I noticed oil on the valve cover, and a bit on the intake downstream of the MAF.
Brand new air filter, and there are no obvious vacuum leaks.
What's next?
Thanks,
Max
Old Jan 24, 2018 | 01:10 PM
rhomanski's Avatar
Welcome to the forum.
Someone will be along soon to point you to the proper forum.
Hopefully our knowledgeable members will be able to help you.
Old Jan 24, 2018 | 01:15 PM
Welcome to the forum Max,
The possible causes of P0171 and P0174 are:
1. Engine misfire
2. Air intake leak between MAFS and throttle
3. Fuel filter, system blockage
4. Fuel injector blockage
5. Fuel pressure regulator failure (low fuel pressure)
6. Low fuel pump output
7. HO2S harness wiring condition fault
8. Exhaust leak (before catalyst)
9. ECM receiving incorrect signal from one or more of ECTS, MAFS, IATS, TPS
P1111 is a status, not an error - all OnBoard Monitoring tests have been completed.
Follow this link XJ XJ8 / XJR ( X308 ) - Jaguar Forums - Jaguar Enthusiasts Forum to the X308 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the US Midwest Region forum by following this link https://www.jaguarforums.com/forum/us-midwest-39/
Enjoy the forums.
Old Jan 24, 2018 | 01:27 PM
Daf11e's Avatar
Welcome aboard Max.
Old Jan 24, 2018 | 02:07 PM
Thanks Jim.
What is the Peugeot 307? We had a 504 in the 70's. They didn't last too long in the US.
Old Jan 24, 2018 | 04:29 PM
Daf11e's Avatar
Not really sure but I believe Nissan had a part in there demise in the USA....
This is my wife's DD....great car!
Old Jan 24, 2018 | 06:30 PM
Old Jan 24, 2018 | 08:59 PM
Hello, Max,
Old Jan 24, 2018 | 11:59 PM
o1xjr's Avatar
Old Jan 25, 2018 | 05:00 AM
Welcome to the Forums.
Old Jan 25, 2018 | 05:41 AM
Welcome to Jaguar Forums Max,
xkeots
Mar 31, 2016 02:03 AM
talashek
Nov 7, 2015 10:40 AM
reddeb
Jan 9, 2015 10:33 AM
jonathanw
Jan 8, 2012 03:11 PM
srpope80
Nov 17, 2011 04:06 PM
