Check your fuel line!
Old Sep 1, 2020 | 08:19 PM
speeedracer's Avatar
Default Check your fuel line!
Working on diagnosing any thing that jumps out on my (new to me) 91 XJ-S and I knew I would do the fuel injector kit but holy cow, I didn't realize how close I was to a major issue. First pic is the condition of the hoses, obviously need to be replaced. Second pic, apparently someone wrapped another piece of hose and clamped it on...Guess she won't be running anymore until I get this redone.
Old Sep 1, 2020 | 08:31 PM
carsnplanes's Avatar
...not to mention the cracked injector connector too.
Old Sep 1, 2020 | 08:59 PM
Dleit53's Avatar
This will be a good time to inspect, and probably rebuild your fuel injector wiring too.
Old Sep 1, 2020 | 09:13 PM
I suspect when I go to the effort of removing that I'll also work on a few other items. In for a penny in for a pound as they say.
Old Sep 1, 2020 | 09:21 PM
VancouverXJ6's Avatar
My god thats a full on blaze waiting to happen.
as with most Jaguar things...while you're there...do yourself the favour of having the injectors professionally cleaned and rebuilt. Wiring is an option to after 30yrs.
I gained nearly 10% fuel flow improvement after mine were rebuilt. There is a filter inside the injector that is always forgotten about.
As for your hose do it all. Buy a spool of proper fuel hose, fuel in and out, injectors, THE TRUNK! Dont forget the trunk lines.
Old Sep 1, 2020 | 09:44 PM
Doug's Avatar
This is exactly why "replace fuel hoses" is always suggested as a must-do !
Old Sep 2, 2020 | 03:33 AM
As Doug has said,
We been warning on this for 20+ years, but so few listen, or even do them.
Old Sep 2, 2020 | 04:33 PM
ChrisHarley2008's Avatar
Just getting all of mine done, including all of the main high pressure lines and the injector lines.
those pics are scary!!
Old Sep 3, 2020 | 07:32 AM
Timeisrelative's Avatar
I keep thinking "I NEED TO DO THE LINES ON MY 4.0!" However most of the fuel line posts I've found have been V12 related. Several of the ones I found for the 4.0 were basically "I changed my fuel hoses" type deal. I'd like to have a better grasp on what's needed and what's involved before I tackle it. Mine "LOOK" ok, but they are still 27years old, so they need done.
Old Sep 10, 2020 | 08:04 PM
Brewtech's Avatar
Interestingly on my 4.0L, I cut into the seemingly good factory fuel line to install an external check valve, and to my surprise, it was in better shape than I had thought. The car has 192k miles and has lived in California since1993.
Old Sep 10, 2020 | 08:25 PM
Doug's Avatar
I'm not entirely surprised. The V12 engine bay is an absolute oven. Everything gets the crispy treatment. Six cylinder cars, less so.
Old Sep 10, 2020 | 09:55 PM
BradsCat's Avatar
look at your ruel line hoses over the rear wheel assembly and the jpnut and return lines in the engine bay. Prevent a tragedy .
purrkittypurr
May 14, 2019 04:59 AM
gccch
Mar 4, 2019 11:31 PM
kmarajh
Jul 21, 2017 04:44 PM
thedugger1
Dec 13, 2015 07:16 PM
alexsneesby
Jun 9, 2010 02:18 AM
