Cherry Blossom - Restoration 1990 XJS V12
Old Oct 28, 2016 | 04:04 AM
  #281
Steve M's Avatar
We don't all have time to hang around tips going skip diving.
Old Oct 30, 2016 | 06:42 PM
  #282
orangeblossom's Avatar
Neither do I
Just right Time and Place.
Old Oct 30, 2016 | 06:51 PM
  #283
Today I put the Water Trap that I got from the Scrap Yard on my Compressor and I think the 'Thingy' on top is a Charcoal Filter?
I'm hoping the 'Thing' in the middle is a Water Trap.
The connection before the Water Trap is just for blowing dust off stuff, while the other one should hopefully Blow Dry Air.
Old Oct 30, 2016 | 07:37 PM
  #284
Default Filling my XJS with Antifreeze
When I fitted my re-cored Radiator, I filled it up with Tap Water just to Test it out for any leaks and was getting a bit of a Weep from the Bottom Hose but as I'd done the Clip up tight, I thought that in time it might Stop.
So as I wasn't using the Car or even Starting Her up, I thought that I would leave it till I got some Antifreeze and do it then.
During which time 'Grant' aka 'The Wizard of Oz' told me where I'd gone wrong, as I was supposed to put the Clip right behind the Ridge of the Bottom Hose Outlet.
So after getting the Antifreeze, I set about draining the Water out of the Radiator by removing the Bottom Hose, which can be a PIA at the best of times, except that I'd used a 'Mikalor' Hose Clip which is done up with a Spanner or a Socket.
Which does make the Job a lot easier.
The elusive hard to reach Hose Clip on the Bottom Hose.
When I drained the Water out, I turned the Clip round so I could do it up from the Top with an Extension Socket.
By Turning the Clip on the Bottom Hose, I can now reach it from the Top with a long Extension Socket which makes it a whole lot easier.
When I finally got the Bottom Hose off, there was hardly any Water in the Radiator, so this time I took 'Grants' advice and positioned the Clip just behind the ridge on the Bottom Hose outlet.
This seemed to work as I still cant see any Weeping from the Bottom Hose.
As I've got very hard water in my Area, I was advised by some Forum Members to Mix the Antifreeze 50/50 with Distilled or De-ionised Water, so I got some and did just that.
De-ionised Water and Antifreeze already for mixing together.
All mixed up and ready to go in the Rad.
I can't believe I'm doing this as I would use Tap Water in any other Car, so this takes Decadence to another level.
I just hope the Neighbours aren't watching or they'll think I've won the Lottery (Again!)
Only a Tenner last time, so I guess that pays for the Water.
No Expense spared, I bought a New Jug and Funnel especially for the occasion!
Old Oct 31, 2016 | 07:16 AM
  #285
ptjs1's Avatar
OB,
Good work. I admit that I get very precise when replacing jubilee clips, working out which is the best position for future maintenance, and then ensuring that I have optimal access with a socket. Like all of you, i have spent many hours trying to reach a jubilee clip and wondering why on earth the previous owner (or manufacturer!) decided to orientate it in that particular direction. The bottom hose on a Renault 1.2 Clio is a specific case in point......
Paul
Old Oct 31, 2016 | 08:06 AM
  #286
paulyling's Avatar
Wow...I am so not used to seeing Blue coolant! I'm only used to messing with Predator's blood!
Old Oct 31, 2016 | 08:10 AM
  #287
Hi Paul
I found that out the hard way!
https://www.jaguarforums.com/forum/x...e-24-a-115152/
Old Oct 31, 2016 | 08:14 AM
  #288
Hi Bro
I think that 'Leaves' a lot to be desired
Old Oct 31, 2016 | 08:47 AM
  #289
paulyling's Avatar
Originally Posted by orangeblossom
Hi Paul
That was gold OB....the forum's # 1 comedic journalist goes to you!
Old Oct 31, 2016 | 10:43 AM
  #290
Daim's Avatar
OB, is that coolant the RIGHT spec? Not being stupid, but loads of different coolants out there and the result was shown when 2 are noncompatible... Costs a lot of time, work and effort to get the problems then sorted...
Old Oct 31, 2016 | 12:07 PM
  #291
Hi Daim
Yes its definitely the right stuff.
Old Oct 31, 2016 | 12:09 PM
  #292
Daim's Avatar
Good... I like to make sure people understand how important this is...
I'll still be using my "universal" stuff from Prestone though... No reaction possible
Old Oct 31, 2016 | 06:33 PM
  #293
With New Brake Pipes on Order (Two Fronts and a Rear) It was now time to remove the Old Flexible Brake Pipes.
As expected they were Rusted absolutely Solid.
Rusted Solid on both sides and the only way to get them off was with a Cutting Disc on an Angle Grinder!
Time for 'The Nuclear Option' sometimes it really is the only way.
I told you they were Rusty!
No amount of Penetrating Oil was gonna shift that!
Nearly There! Lots of patience and a steady hand but don't cut through the Sensor Wires which are just above it.
Finally out and all ready for the New Flexible Brake Pipes (When they arrive!)
All you need is a drop of 'Sea Air' and this happens!
My Sharpest Tool in the Box
A pair of Am-Tech 9in Locking Pliers
However did I manage all these years without them.
Ebay: Around £5
Old Nov 1, 2016 | 02:52 AM
  #294
Greg in France's Avatar
Managing that without making a huge hole in the wing is brilliant OB. Sometimes using the watchmaker's toolkit is the only way!
Greg
Old Nov 1, 2016 | 06:00 AM
  #295
Greg
Hi Greg
You are right, I also made a Video but on playback it was much too painful to watch!
Old Nov 5, 2016 | 12:00 PM
  #296
The next Stage didn't exactly go according to plan!
First they sent the wrong Brake Pipes and then they sent the wrong nuts!
Just a tad on the large side for an XJS!
Pic was on an Old Brake Pipe while waiting for the New ones to arrive.
So while I was getting all that sorted out, I finished off doing the Calipers.
by using a 'Torque Wrench' to tighten the 'Caliper Bolts' doing this in increments up to 50ft lbs.
Using a 'Torque Wrench' to tighten the Caliper Bolts.
Caliper Bolts Tightened up to 50ft lbs
Having Tightened the Caliper Bolts to 50ft lbs the next job was to put the Locking Wire on.
Stainless Steel Locking Wire to Lock the Caliper Bolts.
Putting on the Locking Wire.
You do get Prizes for Neatness
obviously a talent going to waste.
Old Nov 5, 2016 | 01:20 PM
  #297
paulyling's Avatar
Nice one OB. I didn't realise there was nuts with the holes drilled out for locking wire. Is that just for the brake calipers? You'd be "nuts" not to install them though
We use that wire all over the rig up at heights in our derrick and top drive as a nut like that falling from heights is very dangerous
We have a special tool for that wire. Basically like a pair of plyers but has a locking mechanisim and a spindle. You pull back and "wella" it twists all your wire. (probably over kill if you don't have to do too many though).
Old Nov 5, 2016 | 02:21 PM
  #298
ptjs1's Avatar
OB,
Everyone should have a set of locking wire pliers! It's very therapeutic using them! And with a 7" set available for less than a tenner, it's a no-brainer. Much neater than manually twisting wires.
Paul
Old Nov 5, 2016 | 02:30 PM
  #299
ronbros's Avatar
wire twisting pliers, invented at Boeing aircraft Com. Seattle Wa, USA.
its in there museum there!
Old Nov 5, 2016 | 05:49 PM
  #300
Hi Paul (PTJS)
Nice idea but maybe not worth getting with just a couple of wires to do, as I cannot see I would need them for anything else.
Unfortunately 'Rain Stopped Play' or I might have got the Brake Pipes on as well.
