Cherry Blossom - Restoration 1990 XJS V12
Old Feb 22, 2017 | 10:39 AM
  #821
Daim's Avatar
That "reduction" is no issue when it comes to flow or so... Pressure is pressure...
So just remove the hose you currently have between hard pipe to FPR and at the same time the one from FPR to rail and get a shop to make you a fuel pipe/hose about the length of both together with only the fitting from the rail connector. It MUST be pressed with a ferrule. I would recommend having them crimp it on (the ferrules can be pressed/clamped/crimped). You basically only want the diameter of the smaller pipe. It will also fit on the metal pipe from the pump.
That "reducer" (the connector between both hoses) was the first thing I got rid of... Don't want that and even though I am going as original as possible, it isn't being taken over... That can stay in the bin
Old Feb 22, 2017 | 10:47 AM
  #822
Greg in France's Avatar
Originally Posted by orangeblossom
I can either replace it with a New One, or go direct from the Fuel Outlet in the Engine Bay to the Fuel Rail.
This would then effectively cut out the 'A' Bank FPR which was done away with on later Cars (or so I've heard)
Greg was correct, the Fuel Pipe connects to the main Petrol Feed by using a Jubilee Clip, which could not be in a more awkward place to get to tucked under the ABS.
In Theory it looks fairly easy: Just go from the Main Fuel Pipe Outlet (where the Jubilee Clip is) and connect it straight to the Fuel Rail (By Passing the FPR on 'A' Bank)
At this point a couple of Questions:
(1) If I remove the Pipe at the Point where the Jubilee Clip is, would I have to cut anything off the end of the Pipe, or would a New Pipe just Push on, to then be re-clipped.
No, the replacement pipe, one length from here to the fuel rail fitting slips straight on
(2) Half way along the Pipe seems to go into Two different Sizes, so what would I do about that?
This fitting is an ID size stepper down. It is not needed if you go straight to the rail and do away with the FPR
Would it be possible to obtain an OEM Pipe, as used on the Later Cars, that go direct from the main Fuel Pipe to the Rail.
I doubt it as the rails are different
Or I could just buy a New Pipe for the one that seems to have inexplicably melted.
Indeed so, that would be the easiest option, but doing away with the A bank FPR is a good idea, in my view (actually the WoOz's view that he explained to me) as it simplifies the system a bit and has no downside.
If you do decide to run a new pipe direct to the rail from the hardline join by the ABS, the you need to recuperate the piece that is on the rail end of the melted hose. Carefully cut through the swage, and you will then reveal the barbed bit of the screw fitting that the line was swaged to. This barbed fitting is the same size as the hardline, and you just screw the fitting into the rail, as it was before, but connect up the new flexible line to the now exposed barb and do up the jubilee clip. Job done. The final bit is to blank off the vac line spigot that the now removed FPR was connected to the the front end of the A bank manifold.
Greg
Old Feb 22, 2017 | 11:16 AM
  #823
Daim's Avatar
Here a few pictures for you OB just in case you want to make the hose yourself...
Cut the ferrule with a hacksaw... One time each side. Bend it open and you'll see the barbed end:
When removed, clean up the barbs a little bit. If you want to press one on, you can simply buy these cheap ferrule caps at any hydraulic shop. They'll press them on for you too...
Like that you can do them yourself. The hose can't expand under the ferrule so it won't pop off. It can't be overtightend either and is fitted correctly.
You only need one end (the barb in the vice is the one you need) and can simply buy sa 3' of I think it was 8 mm diameter pipe (must be suited for high temperatures! Say between -30 and +120°C. You always want some higher temperature capability, otherwise it can possibly just melt/dry out. The ferrule shown is a cheapy for something like €0,30... I'll be using them again when I do my pipes (next in the pipeline).
Old Feb 22, 2017 | 02:49 PM
  #824
orangeblossom's Avatar
Hi Greg
Many thanks for explaining that so clearly.
I did have a quick look for the Original Part but its seems to be NLA, so it looks like I will have to make one no matter what and may as well do the
long version to cut out the 'A' Bank FPR in the process.
Just one question, does the Main Fuel Pipe into the Engine Compartment also have a Barb on the end, or is it just a smooth Pipe.
It already looks a PIA to get off with the ABS in the way, although I have had to do worse.
Old Feb 22, 2017 | 02:59 PM
  #825
Hi Daim
Thanks for those Great Photos (A picture paints a Thousands Words and all that)
Do you think I should go for the Steel Braided Stuff?
Old Feb 22, 2017 | 03:02 PM
  #826
Hi Grant
Well spotted with the Fuel Hose, you may have just saved my life, I never noticed it before but having had a close look it was frightening.
Old Feb 22, 2017 | 03:04 PM
  #827
Daim's Avatar
Nah, keep with the rubber. The steel braiding makes it look better but the rubber behind will still go brittle with time and you won't see if it is ready to crack open.
I'll be going rubber (with kevlar/aramid reinforcement) to keep the rubber in my eye... I was thinking as well about the braided stuff but after reading around about it, I said no... For the mentioned reason.
Old Feb 22, 2017 | 05:39 PM
  #828
Where can I get Kevlar reinforced Petrol Pipe and push on ferrules?
Old Feb 22, 2017 | 06:30 PM
  #829
baxtor's Avatar
ferrules can be had from agricultural/ tractor suppliers. Try Google push on ferrule fuel hose. That get plenty of hits for me but of course they were local to me and not much use to you.
Old Feb 23, 2017 | 02:09 AM
  #830
OB
The hardline has a barb on it OEM. Just push on the new pipe and a pipeclip. Top notch high pressure (150/200 psi) fuel line can be had from all the normal specialists, Demon Tweeks, Think Automotive,
fuel injection hose
High Pressure Fuel Injection Hose
Fuel Hose Gates 4mm (5/32") Per Metre - Car Builder Solutions - Kit Car Parts and Accessories
I use this sort of clip on these fuel lines, be sure to get the correct size, to JUST fit over the OD of the hose before tightening.
MINI FUEL LINE STAINLESS STEEL JUBILEE HOSE CLIP CLAMP DIESEL PETROL PIPE clamps | eBay
Be sure to get a top quality make, Gates, Sytec, are very good. be sure to know the ID you need, too, by measuring the UN-raised bit of the barbed end the hose is fitting onto.
Greg
Old Feb 23, 2017 | 04:30 PM
  #831
Hi Daim
Cheers!
That's a good idea!
Much better to be able to keep an eye on the hose.
Old Feb 23, 2017 | 04:38 PM
  #832
Hi Greg
Cheers!
That 'Sytec' Hose looks the business but do you happen to know what inside diameter I would need.
(Massive problems with the Weather To-day!)
Old Feb 23, 2017 | 04:47 PM
  #833
Daim's Avatar
8 mm id
Old Feb 23, 2017 | 05:13 PM
  #834
Hi Daim
Cheers!
8mm sounds about right from what I've been reading.
(your turn next for the Storm! keep Safe it was horrendous!)
Old Feb 24, 2017 | 02:22 AM
  #835
Daim's Avatar
It had been storming all day yesterday. Totally quiet now again. No damage what so ever outside... Strong trees around here
Old Feb 24, 2017 | 03:44 AM
  #836
Measure it with calipers if you can OB. It is actually an imperial size, probably 5/16 inch, which is damn nearly 8mm according to my online converter. 3/8 inch would be 9.5mm. Gates make imperial sizes, and one at least of the links I posted earlier quotes imperial sizes.
Greg
Old Feb 24, 2017 | 07:21 AM
  #837
Hi Greg
Cheers!
I will try and get a Caliper on it but its in the most inaccessible place that you can imagine, so getting the old pipe off and the new one on, doesn't
exactly look like a 'walk in the park'
Would it be such a 'Bonkers' idea to take the (long fuel pipe) off the FPR on 'A' Bank then just change the fitting on the end and screw it straight
onto the Fuel Rail, using a push on Ferrule?
Old Feb 24, 2017 | 07:31 AM
  #838
If there is enough pipe for a sensible piperun, it would be OK. But I think you will find there is not. Also, I think, repeat think, the ID of the pipe running from the stepper-downer in the flexible part of the supply pipe to the FPR is too small to get on the rail fitting. The reason for the stepper-downer being that the FPR has a smaller spigot on it than the hardline and the rail fitting.
My advice is not to bodge it, but to do a proper job with a good, unstressed piperun from the hardline to the rail that runs roind the end of the A bank cam cover well away from any chafing, hot engine bits etc etc; a bit like this pic shows.
Greg
Old Feb 24, 2017 | 07:56 AM
  #839
Hi Greg
Cheers!
I will take a look and see how long the pipe is but I may as well get a new piece anyway.
Old Feb 24, 2017 | 08:04 AM
  #840
Daim's Avatar
Greg
That is the advantage with the press on fittings. You can have them crimped onto the hard plumbing of of the injector rail/FPR and use a wider diameter hose.
