Cherry Blossom - Restoration 1990 XJS V12
Old May 21, 2017 | 06:56 AM
  #1101
leo newbiggin's Avatar
fashion is for followers. nothing wrong with a prawn cocktail, also a black forest gateaux.
rum and coke is for after drive relaxation. getting hammered is a great hobby,one i indulge in whenever i am able
Old May 21, 2017 | 12:38 PM
  #1102
Jonathan-W's Avatar
after a drive... a good Port!
Home - Waugh Cellars
distantly related... and mostly out of my price range... (shipping form CA is pricey )
while repairs, Jack Daniels or Wild Turkey/Honey (to help lick the wounds )
Old May 23, 2017 | 07:31 AM
  #1103
orangeblossom's Avatar
Having had a problem bleeding the Front Brake on the drivers side (UK) Car, I thought it may have been an Air Leak in one of the Brake Pipes I made.
So I replaced it with another one.
I thought that one of my home made Brake Pipes may have been sucking in Air and so I made another one to replace it.
But since this didn't solve the Problem, I did a Test on the Valve Block of the ABS and found that one of the Valves didn't seem to be working.
So I then removed the Valve Block and had a look inside.
No Wonder the Brakes weren't working, years of Standing have certainly taken their Toll.
The next thing I did was remove all the Ribbon Connectors (some I did before I took this Pic) and having then removed the Valves.
I took them to a Jewelers for Ultrasonic Cleaning in their Industrial Machine.
Then took the lot to a place I know that Specializes in repairs to electrical stuff, together with a diagram of what to Solder where and left them to it.
Although I have done this myself in the past, its quite a fiddly little job that does require a lot of attention to detail, as you can't afford to get this wrong.
And so for the sake of £25 to have it rewired by professionals, it seemed to be worth it as at least I will know that it works.
Meantime we went to an Auto Jumble on Sunday, where 'The Jaguar Gods' were really on my side.
As I picked up a Complete Pedal Box Assembly including the Master Cylinder Actuator for an XJS for £100.
Where you can see from the Brake Pedal Rubber, that it doesn't look as if its really done much work.
The Master Cylinder Actuator for a Pre-Facelift XJS including the Valve Block only for £100.
The Pedal Rubber was hardly worn, so doesn't look as if its really had a lot of use.
Then just when I was thinking that it doesn't get better than this, it suddenly did!
Look what I found Brand New for only £50!
A Brand New XJS Valve Block only 50 Quid OMG Bargain or what!
Now that's what I call a Bargain as it was just what I wanted but since I've also bought a Complete Master Cylinder Actuator, I might just put that in to try it out.
As it should only take me a couple of hours to Swap over and maybe an hour or two to Bleed the Brakes.
To be Continued.........
Old May 23, 2017 | 09:35 AM
  #1104
Daim's Avatar
Where did you live again OB? I mean, now that you have so many ABS parts, it would be a shame if a couple went 'missing'
Old May 23, 2017 | 11:03 AM
  #1105
Hi Daim
Ha! I see you are on the prowl for some of my stuff but I don't even know if it works yet!
Though the people rewiring my old Valve Block are certainly taking their time, as I took it over to them a few weeks ago.
They probably regard it as a bit of a nuisance job, as they are more used to working on more complicated stuff.
So when I eventually get it back, I'll keep it as a Spare.
The Master Cylinder Actuator with the Pedal Box, only took me an hour to put in, so at the moment I'm just connecting the Pipes up.
Then I'll Bleed the Brakes and see what happens.
The only other problem that's reared its ugly head, is a Water Leak.
The Clip on the Top Hose was a bit loose, so I've tightened it up and hopefully that should fix it.
This type of Weather is perfect for working on Cars and the Engine runs better than ever.
Fingers crossed its all ok this time.
Old May 23, 2017 | 11:11 AM
  #1106
Daim's Avatar
I am sure mine as rusted out inside... That is on my "to do" list yet... Not looking forward to it but I do prefer to drive a car with ABS. Not because I am a wuss but because ABS gives you that extra when it comes to braking.
Old May 23, 2017 | 11:43 AM
  #1107
Hi Daim
Stopped for 'Tea Break'
Providing the Valves are working OK then fixing the ABS is very easy, though you must be 'Ace' at Soldering or you could Kill yourself (Just so you know!)
That's why this time I subbed that Job out to the Pro's.
Old May 23, 2017 | 11:45 AM
  #1108
Daim's Avatar
I don't solder that often but where I work my colleagues do it all day On mircoscopical level
Old May 23, 2017 | 01:22 PM
  #1109
Hi Daim
No Shame in subbing the Soldering out or taking the Valves for a Professional Ultrasonic Clean.
As the object of the exercise is to make it good as new, without spending a fortune.
Old May 26, 2017 | 03:19 AM
  #1110
The Restoration of 'Cherry Blossom' is now gathering pace and as most of you know the Oil Cooler broke when I Started her up after 16 years of Standing.
As I didn't want to replace this at least until She has passed her MOT, yesterday I got myself an Oil Cooler by-pass pipe made up.
Which I got done for a 'drink' by a guy who has just Started up in the business, so in any event that's one useful Contact I made.
The Oil Cooler by-pass Pipe that I had made up
As there was not much space to move, it was a bit of a 'nightmare' to get the connections done up but once it was in, it curved round without any 'flat spots'
The Photo taken was of a trial fit, before I cut the pipe to length to have the Connectors crimped on, where for the actual fitting I used the proper joint tape.
Oil Cooler by-pass Pipe now in position for a Trial Fit.
The Drive Belts are nowhere as near as they look in the Photo, with plenty of clearance all round.
Oil Temperature taken after half an hour of driving round the Garden 110 degrees.
Old May 26, 2017 | 01:25 PM
  #1111
Daim's Avatar
OB, just to make you "giggle" a little...
As I had to remove my tranny from my XJ8, I was forced to cut a pipe. This pipe is now taking revenge... Not only, can I not get the car to run without this pipe, this pipe is only properly accessable with the engine outside of the engine bay...
I guess you know where this is heading to
You're right! Engine must come out. A "simple" removal. Shouldn't take "that" long - I hope. And to complete it: it will have to come out on the front subframe, which is luckily enough able to be removed with the engine on it...
Wohooo! I "love" my cars... Actually, I hate the XJ8 at the moment... I won't be cleaning the engine or the engine bay at the same time. Sod that! Throw away item!
Old May 26, 2017 | 05:47 PM
  #1112
Hi Daim
I'm gutted for you!
What on Earth have you done now, as you seem to break your Cars as fast as you fix them.
So its a good job you're an Expert at taking engines out, which should be a Walk in the Park for someone with your Skills.
As for me I've just replaced the Master Cylinder Actuator, which has made a big difference to the Braking.
Though the biggest problem I've got now, is getting the rear Wheels off, as they are stuck on the rear hub carriers.
And though I've been doping them with Oil, they just won't come off and so it is going to take the biggest of FBH to try and un-stick them.
Old May 27, 2017 | 04:12 AM
  #1113
Daim's Avatar
Stuck wheels? Undo the nuts and leave a couple on. Then simply jack the car as high as possible and drop it. Normally it is enough to undo the 'bond'
Old May 27, 2017 | 05:30 AM
  #1114
You cannot be Serious!
I'll try the FBH first.
Old May 27, 2017 | 07:50 AM
  #1115
Daim's Avatar
Do you think that'll damage anything? Hitting the wheels with an FBH does more damage. You don't drop it from 3' on the ground. 1' is more than enough...
Old May 27, 2017 | 09:42 AM
  #1116
Doug's Avatar
Or.....
Another popular method, if the car is drivable, is to loosen all the nuts a bit and then slowly....like 5 mph.....drive the car in a couple "figure-8" patterns.
Old May 27, 2017 | 11:08 AM
  #1117
JagCad's Avatar
A bit over a decade ago, I observed/participated in a technical examination of an old truck. My former career. Brakes an issue in the accident that allegedly seriously injured
the teen driver.
One of the "technical" experts was an experienced tech from the local Ford dealer.
Removing a rear brake drum was an issue. The wheel was off. The tech went to his truck and came back with two hammers. Using both hammers he whacked the drum soundly at spots 180 degrees apart a few times. It came free. That experience thing
prevailed. Force has it's place, properly applied.
Carl
Old May 28, 2017 | 05:50 AM
  #1118
Hi Doug
Not quite enough room to do a figure eight, so I will try and protect the alloys with a piece of wood and then whack it with a Sledge Hammer.
Old May 28, 2017 | 06:30 AM
  #1119
if you pour boiling water on the alloy close to the hub it may expand enough so you dont have to hit it too hard. maybe worth a go, only costs a kettle
Old May 28, 2017 | 06:53 AM
  #1120
ericjansen's Avatar
I had the rears of our SLK frozen, impossible to get them off.
However, bolts a couple of turns loose, <1 meter backwards and slamming on the brake solved it.
Don't go the sledge hammer way...
