Cold Start Issue
Old Dec 31, 2021 | 10:18 PM
  #41
Vinman12's Avatar
Yes 4 wire, comes with new rotor, 4th wire goes to middle wire on ballast resistor, I also will be rebuilding the 12 injectors
Old Jan 1, 2022 | 05:45 AM
  #42
JayJagJay's Avatar
Originally Posted by Vinman12
I have a new trigger board in the way (ebay $100.!) And a rebuild kit for all 12 injectors for $102.00, maybe that will do the trick.
I think "rebuild" kit means all the rubber and soft bits. Still may not get ya to freeing up the gunk, debris and just plain ol stuck-ness on the INSIDE of the injectors... It's the insides that need some love, I'm guessing
Old Jan 1, 2022 | 09:00 AM
  #43
Vinman12's Avatar
A little carb cleaner , some air pressure and add 12 volts for a milli second always does the trick ! Have done it at least 20 times in the past
Old Jan 1, 2022 | 12:09 PM
  #44
Greg in France's Avatar
The rebuild kit includes (at least should include) the tiny basket filters that go into the top of the injectors. If these are gunked up, which they probably are, then replacing them will make a huge difference.
Old Jan 1, 2022 | 12:37 PM
  #45
Vinman12's Avatar
Yep, comes with filters, seals, hoses and clamps and pointless caps, should be here in a few days and they the fun begins
Old Jan 1, 2022 | 12:47 PM
  #46
Vinman12's Avatar
have a trigger board coming in a few days, the kit has everything except the seller said the 4 red bushings that mount it are missing, any idea as to where i can get those little bushings that go on the board ????
Old Jan 1, 2022 | 09:14 PM
  #47
Oh dear.
I made some for one of mine a very long time ago.
Memory is not behaving at the moment, so when it kicks in, I will edit this post with how I did it.
Same for the Nylon screws, I used something else?????
I have notes in the shed somewhere, but 41c in that tin box, not happening.
Have a stooge around SNG, they have some oddball stuff.
What I remember.
Those rubber things were never easy to find, even back 30 years ago when parts were plentiful.
I used "fine thread" screws (part f my huge hoard of stuff over 55 years), and they threaded into the distributor perfectly.
A brass tube over said screw to set the board height, so fiddle an fart with length.
Fibre washer under the board, fibre washer on the top side (under the head of the screw).
That is the basics of 3 of mine. NOT rocket science, but fiddly as hell. About 6 beers should see it done.
One of mine done like that is now at 655000kms, and never missed a beat.
Dustin Moorman
Jan 10, 2023 08:42 PM
Obi
Aug 9, 2021 11:55 PM
Gus
Mar 4, 2017 10:16 AM
layada
Jan 10, 2017 02:18 PM
