Could a (UK) MOT damage the Diff of the IRS?
Old Mar 20, 2014 | 07:17 PM
orangeblossom's Avatar
Default Could a (UK) MOT damage the Diff of the IRS?
I'm shortly due to take my XJS V12 for a UK MOT where they do the brake test using the rolling road.
Not a problem for most cars I think? but the IRS on the XJS has a limited slip differential and I am just a bit concerned that the diff might get damaged as they brake each wheel independently when testing the brakes.
I always mention that the car has an LSD but they still use the rolling road.
Has anyone encountered any problems, when they do the test this way?
Or am I just being 'Paranoid' as usual?
Old Mar 21, 2014 | 02:27 AM
Greg in France's Avatar
You have nothing to worry about at all.
Greg
Old Mar 21, 2014 | 08:03 AM
Greg
Thanks Greg that is a relief!
One of 'The Old School' Testers used to put a braking device thingy on the dashboard and then take it for a Test Drive.
But they don't do that anymore.
Old Mar 21, 2014 | 09:43 AM
Mikey's Avatar
Greg
Agreed. There's nothing a rolling road can do to the diff that even comes close to the stress of regular driving.
Old Mar 21, 2014 | 03:20 PM
Tyran66's Avatar
The vast majority of performance cars now have an LSD as standard, the rolling road won't touch it. Even Dana cannot defy the laws of physics.....well...mostly.
Old Mar 22, 2014 | 06:35 AM
texasscot's Avatar
When I lived in the UK I found the MOT test would always cause brake pipes to instantly corrode resulting in another expensive repair.
Old Mar 22, 2014 | 09:53 AM
Tyran66's Avatar
@texasscot - that's a favourite of scamming MOT centres. Just ask them which one and to show you, most of the time its utter BS but I have a feeling your already well ahead of the game on this one
Old Mar 22, 2014 | 09:56 AM
Mikey's Avatar
I think the quick oil change places on this side of the Atlantic have contracted the same disease.
Old Mar 22, 2014 | 05:16 PM
Same thing happened with my Merc on one MOT that I had, where they said the Brake Pipes were corroded.
But then they had to change their minds when I pointed out that I had replaced them with copper about 5 years ago and what they could see was nothing more than natural discoloration.
Also the nearside headlight and rear light didn't work!
At which time I had to explain that on a Merc, you can switch these off, to help conserve your battery when you park by the side of the road and just in case you hadn't guessed.
They had turned the switch to the wrong position!
So if they think I'm taking my Jag there, then they have another thing coming!
Old Mar 22, 2014 | 05:19 PM
I wouldn't know, I wouldn't trust them to do it!
jorgef858
Jan 14, 2016 11:32 AM
Dave1109971
Dec 15, 2015 06:16 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
