Crank position sensor
Old Aug 29, 2025 | 07:47 AM
wardhill68's Avatar
Default Crank position sensor
Ive replaced mine twice still nostart. Mechanic claims they are getting a p0335 code and wanted to replace the cps with a $500 oem cps . What aftermarket cps have folks had good lick with? The ones i bought were cheap ebay china ones. Thanks
Old Aug 29, 2025 | 02:18 PM
ptjs1's Avatar
Jeff,
I wouldn't be changing any more parts at this stage. I would look at the electrical diagram and backprobe all the input and output signals on the ecu plug to establish whether the problem is one of the input signal conditions, or one of the output signals.
Good luck
Paul
Old Aug 30, 2025 | 07:50 AM
wardhill68's Avatar
That’s what I’m planing to do starting with fuses 7 and 14 as suggested. Id love some additional instruction on back probing the ecu. I’m not that experienced with electrical
Old Sep 2, 2025 | 04:02 PM
Vee's Avatar
Vee
I've successfully used Walker and A-Premium from Amazon. Both under $30 at the time.
Old Sep 4, 2025 | 04:43 AM
Asdrewq's Avatar
I recently used the cheapest CPS's I found in eBay - I think they were £26 each or similar, and they work fine.
Old Sep 4, 2025 | 01:43 PM
wardhill68's Avatar
Yes there are some realy cheap ones but im buying a different brand thistime thats a little more money. If this doesnt work i may try it in my working 97 xj6. Ive just been hesitant about disabling another car
Old Sep 4, 2025 | 01:44 PM
wardhill68's Avatar
Thanks . Ill keep that in mind for the future
ForTheLoveOfCars
Dec 5, 2023 10:02 AM
dcjag22
Oct 4, 2022 06:47 AM
Spud Maat
Sep 14, 2022 03:02 AM
stevepaa
Oct 28, 2021 08:28 AM
Idrivejags
Dec 1, 2008 07:26 PM
