cruise control
Old Aug 2, 2020 | 06:21 AM
BradsCat's Avatar
Default cruise control
As I revitalize my 87 coupe and part out the 88 H & E convertible one of my goals is to get the cruise control on the 87 actually working. I've had the car since '92 and it has never worked. I did replace the vacuum actuator once and have tested the little electric plungers to ensure they are working. The bellows is fine, no cracks. And it is completly sealed with silicone.
Question: Should I continue to pursue the original bellows style set up or is is possible without major engineering to replace it with push rod style unit from a later year car?
Old Aug 2, 2020 | 08:03 AM
Doug's Avatar
I have no experience with the later system so I can't comment on any advantages it may have.
However, if your existing bellows is sealed and tested, as you say, that's 75% of the battle. Getting your existing system to work probably won't be too difficult.
Old Aug 2, 2020 | 08:04 AM
Doug's Avatar
This should help
Cruise Control
Old Aug 2, 2020 | 09:03 AM
Greg in France's Avatar
The later push rod capstan/cruise system will not easily go, if at all. The diameter of the push-rod capstan is much smaller, and so the original throttle cable/pedal travel will not work properly.
Old Aug 2, 2020 | 09:31 AM
BradsCat's Avatar
Thanks, Don't want to waste time pushing a a wet noodle uphill.
Old Aug 2, 2020 | 09:33 AM
BradsCat's Avatar
Originally Posted by Doug
This should help
Cruise Control
Thanks, I am sure it will work with enough testing and parts replacement if necessary. My goal is everything works as intended by Christmas.
Old Aug 2, 2020 | 02:26 PM
jag-reflex's Avatar
Make sure the switch at the base of the gear shift is working correctly and that your electrical connection to the brake booster and the brake fluid reservoir cap are good. Nothing will work if they're not. My car is the same as yours so check back if you get stuck.
Old Aug 2, 2020 | 07:56 PM
BradsCat's Avatar
Thanks, will do.
Old Aug 3, 2020 | 12:12 AM
baxtor's Avatar
If you haven't already you may need to check the condition of the tiny sealing pad on the solonoid plungers. Even though the solonoid might be ok electrically, the pads can harden with age and can also come unglued and no longer seal.
Old Aug 3, 2020 | 08:38 AM
BradsCat's Avatar
Thanks, I will double check them. I have a spare solenoid if needed so that's is a big help.
superchargedtr6
Jun 30, 2014 09:05 PM
dtony
May 23, 2014 07:27 AM
RagJag
Sep 13, 2012 01:13 PM
tylerwerrin
May 25, 2012 02:32 PM
86JAGVP
Sep 11, 2011 06:45 AM
