Cruise Control - Full speed ahead... literally !!!
Old May 3, 2020 | 01:57 AM
Dukejag's Avatar
Default Cruise Control - Full speed ahead... literally !!!
Just like the title say... when I turn on my cruise control the car starts accelerating and does not stop unless i turn it off.
Any idea where to start?
I have not looked at the adjustment pots yet, or tried my light setup but will be.
Old May 4, 2020 | 07:09 PM
Some Day, Some Day's Avatar
Not sure if this is the same issue, but it might provide a place to start looking.
XKS Unlimited Tip
Old May 4, 2020 | 07:34 PM
Doug's Avatar
Here's some reading that might cover the problem
Cruise Control
Also, there's an adjustment to 'trim' the cruise control speed. It's on the cruise control module. My gut feeling, though, is the problem you're describing has something to do with one of the little valves in the cruise control servo assembly. The article linked above discusses the valves
Old May 4, 2020 | 07:37 PM
Doug's Avatar
XKS Unlimited Tip
Good catch, but that bushing was used on the later Hella cruise control. An '89 would still be on the earlier Econocruise system
Old May 4, 2020 | 07:53 PM
jag-reflex's Avatar
Yeah, mine did that. The adjustment pots took care of it. If you're lucky that's all it will be.
Old May 5, 2020 | 12:39 AM
Dukejag's Avatar
I have rebuilt the cruise control system, so my fingers are crossed.
Pulled the cruise control module - there are two pots... which one to adjust?
Thanks for the links.. it seems the adjustment is very fine.
Old May 5, 2020 | 07:46 AM
Doug's Avatar
[Foggy memory disclosure here]
With the cover in place there should be a small port that makes one of the pots accessible. That would be the one to adjust.
Old May 5, 2020 | 08:49 AM
jag-reflex's Avatar
The one on the left im front of the yellow box cap. While driving is best..turn it counter-clovkwise to reduce the engagement speed. A little goes a long way. It's a fiddly business..you need an assistant. if you go too far the cruise won't engage so you can verify that this is the culprit pretty easily.
Old May 5, 2020 | 09:39 AM
jag-reflex's Avatar
I've read about the access port thing. Mine doesn't have one for sure. Maybe they added it later..or took it away?
Dregun
XF (X260)
Nov 14, 2019 01:11 PM
Diddion
Jun 9, 2017 05:42 AM
QuikCat
Mar 20, 2014 10:27 AM
Kaibigan
May 1, 2012 05:09 AM
Davexjrv8
Nov 29, 2011 09:38 AM
