Darn light does not go off!
Old Dec 18, 2012 | 04:58 PM
newguy's Avatar
Default Darn light does not go off!
The light in the dashboard indicating that one bulb is out does not want to turn off. I have checked every bulb there is inside and outside the car incl. the 2 lights in the trunk and the one in my flashlight that is stored in my non-existing glove compartment .
May this be something else than a blown bulb?
Old Dec 18, 2012 | 05:51 PM
2l8and1's Avatar
Mine did the same thing to me. had a headlight out (idiot light was on for weeks before I replaced it) and after replacing the high beam headlamp, the idiot light stayed on.. hmmmm I thought. so I disconnected the negative terminal to the battery, (wondering if it was light a check engine light) hooked it back up and BAM... the idiot light came back on =[ ... BUT only for about 2 minutes then went off. Now everytime I start the car, turn on the headlights, and hit the road, the light comes on for a couple minutes and then cycles off till the next time. Not sure why, but I can live with that better than it being on all the time.
Old Dec 18, 2012 | 07:36 PM
Not sure about the '95, but on the earlier cars that idiot light always came on when the lights were activated and then cycled and went out if all was well, stayed on if one was out. Its a time/Lucas thing.
My'85 played silly buggers in the early days and it turned out to be a number plate bulb, it was working, but as dim as hell, and it was the contacts badly tarnished, cleaned those contacts, 15 years later, all good.
The parking bulbs at teh front can also trigger this light.
Again, this is the earlier cars, but the system is more than likely the same basics.
Old Dec 19, 2012 | 08:27 AM
Bill C's Avatar
This may be an obvious one but..
Are you sure the parking brake is fully released?
Old Dec 19, 2012 | 04:29 PM
anjum's Avatar
I can rest easy now for certain. Came to the conclusion that it was normal, now I have confirmation, thanks, Grant. Mines a 92 1/2 facelift.
Old Dec 19, 2012 | 07:14 PM
mrtalkradio's Avatar
I second the motion. It has about a 2 minute cycle when you first put your lights on, if all is well it goes out.
Old Dec 20, 2012 | 04:31 AM
We need a DRINK.
Another Jag with a simple problem solved, DAMN we are good.
Old Dec 21, 2012 | 06:45 PM
newguy's Avatar
I will disconnect the battery and cross my fingers - thanks 218and1. My lights stays on ALL the time.
An no, it is definitely not the parking brake light - I know what that looks like as I have driven many miles with the parking break one (how can see the lights during daylight anyway?)
Old Dec 21, 2012 | 07:05 PM
Bill C's Avatar
Well, actually what I meant was, if the Parking Brake is on, and the lights are turned on, the Bulb Out indicator comes on and stays on.
Hope the disconnect worked.
Old Dec 21, 2012 | 07:24 PM
FastKat's Avatar
We need a DRINK.
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
Mosers63
Sep 6, 2015 02:53 PM
