dashboard lights
Old Mar 23, 2015 | 04:32 PM
yabaman's Avatar
Talking dashboard lights
Hi Guys
I have two symbols lighting up on the dash and I cant really figure them out.
First the handbrake symbol is continuously on even as though the handbrake is disengaged and second , the orange symbol which is supposed to glow when you have a burnt bulb keeps turning on every time I press on the brakes. My car is a 1990 XJS 3.6.
Any ideas anyone?
Old Mar 23, 2015 | 08:30 PM
malc4d's Avatar
Maybe brake light bulb needs replacing ??
Old Mar 23, 2015 | 09:30 PM
snowball's Avatar
For the hand brake, check the switch at the base of the hand brake handle, I had a '91 and the switch was tricky, same thing stayed on.
Snowball
Old Mar 24, 2015 | 12:38 AM
user 652867429824's Avatar
check the switch on the hand brake, it may just sticking and needs a bit of cleaning. also make sure the brake is off. I have a 84 XJS and if its like mine, the handle goes done after it is applied, you then have to pull up and press the button to release it. For the light comeing on when the brakes are applied, (Haven't looked at my manual lately) but I think it does that to let you know the system is okay
Old Mar 24, 2015 | 02:39 AM
Greg in France's Avatar
The bulb out warning light has a test mode, which is handbrake on, ignition on, press the footbrake and it illuminates if it is working properly. You either actually DO have the handbrake on, or at least the microswitch in the handbrake mechanism is not operating properly.
It is a sod to get at without removing the seat, but then the cover comes off easily and you can adjust the switch.
Greg
Old Mar 24, 2015 | 03:53 PM
yabaman's Avatar
Thanks guys.......ill get to work asap
Jpav27
Jul 31, 2022 06:43 AM
redrover41
23
Sep 25, 2015 01:33 PM
simo5555
Sep 9, 2015 06:22 AM
Saturbo
Sep 8, 2015 07:35 PM
XFR_Gold
Sep 2, 2015 12:24 PM
