Differential oil
Old Mar 3, 2018 | 11:29 AM
brinny's Avatar
Default Differential oil
My 89 convertible has a 2.88 diff lsd I believe. Can anyone tell me which oil to use and how much I will need. Many thanks for any help.
Old Mar 3, 2018 | 12:22 PM
Doug's Avatar
I use any name brand 80/90 GL5 gear oil. Some already have a limited slip additive and will say so. If not you'll need to buy some. The GM part number is 1052358 but (here in the USA, at least) every local parts store carries an equivalent.
I think the capacity is about 2.25 US quarts
Someone with a manual close to hand will verify
Old Mar 3, 2018 | 01:42 PM
ronbros's Avatar
i'm trying to justify a leak in my diff, it leaks about a pint of lube in about 5 yrs?
more messy than anything else!
i use the GM LSD lube most of it is 24yrs old now, but looks very clean, SO the question is,(DUHH)>
Old Mar 3, 2018 | 02:12 PM
Greg in France's Avatar
Brinny
Use Castrol Syntrax LSD, this is the best and most easily available in the UK. Do not use non-LSD diff oil, they are not the same.
Amazon Amazon
Most places have it.
Old Mar 3, 2018 | 06:38 PM
Doug's Avatar
IMO, leave it alone. But, I have a pretty high degree of tolerance of oil leaks. I only go after the gushers. Oooozers and tiny-drippers I ignore on any old car.
Old Mar 4, 2018 | 03:31 AM
brinny's Avatar
Brinny
https://www.amazon.co.uk/Castrol-Syn.../dp/B008R78YCY
On its way thank you. For general info it states in the handbook 1.6litres from empty . Thanks for the replies.
Old Mar 11, 2018 | 06:10 PM
Benj628's Avatar
I'm quite surprised that this is the only thread on the differential I can find. I want to learn more about it and what oil, how often to change, etc. but this is the only one I can find. Surely there are others?? I'm wanting to learn how to do it myself after checking to see if it needs to be done.
Old Mar 12, 2018 | 02:57 AM
Changing it/checking the level is a good plan every 20,000 miles or so, I think. If you have a diff with a drain plug, this is relatively easy. If not, and the DANA diffs like mine do not, not so easy. Fill is also hard work, but quite doable axle in car.
My solution is to change the diff oil every time I have the rear axle out to fix the brakes or something else. Seems to happen about every few years...
You must used diff oil specially made for LSDs though, as noted with an example in the posts above.
Old Mar 12, 2018 | 08:09 AM
Doug's Avatar
I change diff oil every 30k miles
First and foremost, never remove a drain plug on anything until you are sure you can also remove the fill plug
Reaching the fill plug for checking the level or adding oil can require some contortions but it's doable. Removing the tie-plate helps quite a bit, in my experience....but doing so is, in itself, a bit of a chore. Lots of fasteners.
Before removing the fill plug brush away any debris/dirt in the area so it doesn't inadvertently fall into the hole
To top-off or re-fill I use a rubber hose hose attached to the bottle of diff oil and just squeeze the bottle to push the oil through the hose.
Old Sep 21, 2018 | 01:39 PM
MIFoodie's Avatar
Hi. I have a 1990 XJS with the axle out right now. I will be changing the diff fluid, Does anyone have a picture of where the fill hole is? I see the hole for the sensor. Is that it ?
Old Sep 21, 2018 | 02:03 PM
Doug's Avatar
The filler hole is just a couple inches below the sensor. Item #3 in this illustration id the filler plug
https://www.jaguarclassicparts.com/u...mbly-5-3-litre
Old Sep 21, 2018 | 02:08 PM
MIFoodie's Avatar
Thanks. I would have overfilled.
rinwort
Mar 10, 2009 10:22 PM
mr.xtype
Jan 24, 2009 07:10 PM
Dandercat
Dec 16, 2008 01:42 PM
