Does draining the 'Sludge Tank' appear as an item in any XJS Main Dealer Service?
Old Sep 12, 2016 | 03:58 PM
orangeblossom's Avatar
Default Does draining the 'Sludge Tank' appear as an item in any XJS Main Dealer Service?
Tomorrow I'm planning to fit a brand new Fuel Pump, so I thought I would drain the 'Sludge Tank' and clean it out, plus the fitting of a New Fuel Filter.
Thanks to advice from Greg and Grant no need to pay £100 - £200+ for a Pump as they are a common fittment on lots of other Cars.
So I picked one up for £35 with a 2 year guarantee, which should be arriving tomorrow.
But seeing as draining the 'Sludge Tank' is such an easy job and is only held in with four bolts if you need to take it out.
My Question is: Does draining the 'Sludge Tank' ever appear as an item in any Main Dealer Service? as unless I've missed it, I couldn't see it myself.
The Photo shows a fuel pump of the type that is fitted to lots of other Cars and as such can be purchased for around £35.
Old Sep 12, 2016 | 06:07 PM
xjsman89's Avatar
No idea if it was ever a service item, all I know is that there is a "pre filter" that goes on the pickup tube in the sump tank in addition to the main fuel filter behind the spare tire. When I redkoted my tanks I replaced both the pre filter inside the simp tank and main filter. It's pretty cheap, I got one from SNG. Be sure to grab a new gasket for the pickup tube too, as the old one is certainly a little drier than a new one.
Old Sep 12, 2016 | 10:03 PM
Nope.
Alan, its a "Sump tank", if you got sludge back there you are in more strife than Ned Kelly on a bad day.
Old Sep 13, 2016 | 01:09 AM
Greg in France's Avatar
Only changing the sock filter on the outlet spout is a service item; BUT, Jaguar's procedure is to drain the sump tank to change it, so that would effectively flush out any crud in there on a regular basis.
Greg
Old Sep 13, 2016 | 02:14 AM
You would think they would drain the Sump Tank, as a matter of course, if only to flush out any droplets of water that may have accumulated over time.
Old Sep 13, 2016 | 02:16 AM
Originally Posted by Grant Francis
Nope.
Maaaaate
'Sump Tank' sounds so much better! so I'll be using that word from now on.
Old Sep 13, 2016 | 02:18 AM
Greg
Hi Greg
Thanks, I'm hoping not to find any but we'll see.
Old Sep 15, 2016 | 10:17 AM
xjsman89's Avatar
Originally Posted by orangeblossom
Hi Greg
Mine had been sitting for a few years and the guy who had it didn't drain the fuel, so I had rust in both tanks. I had them cleaned out and coated. Hopefully this isn't what you find, but it's definitely fixable if you do! I'm glad I checked them, it would have been a bad day if any of that rust got through to the injectors!
lc3566
Jul 16, 2017 07:43 AM
patpin
Aug 31, 2016 01:33 PM
sflowers
Aug 31, 2016 02:52 AM
Salu498
Aug 29, 2016 12:13 PM
SinF
Aug 23, 2016 10:51 PM
