Door mirrors
Old Oct 9, 2024 | 09:24 AM
malc4d's Avatar
Default Door mirrors
My latest usual "late night " ebay purchases are a pair of body coloured door mirrors. Keep wondering if l should take the chrome ones off and fit them.
I did try fitting 1 and the wiring seems to be fixed inside the door. So guessing door panel off job. Bugger !!
Old Oct 9, 2024 | 04:19 PM
ptjs1's Avatar
Malc,
You should be able to fit facelift mirrors without taking off the door panel.
From memory, the plugs may be clipped to something on the door, but they can definitely be freed up. The rule is that must not disconnect them from the mirror, when you remove the mirror, without first attaching a piece of string to them, as they will fall back into the door void . Then you WILL have to remove the panel if you can't pull them back up with the string!
Paul
Old Oct 11, 2024 | 10:10 AM
equiprx's Avatar
I don't believe the plugs are the same from 91 to 94 when body color mirrors come in.
Old Oct 11, 2024 | 01:49 PM
ptjs1's Avatar
I THINK that all facelift mirrors from 1991 (VIN 179737) to the end of production use the revised green wiring plugs
Paul
Old Oct 20, 2024 | 09:03 AM
malc4d's Avatar
Yup, these have the green plugs. But are somehow clipped inside the door so the door panel has to come off....sometime..
Old Oct 20, 2024 | 10:09 AM
ptjs1's Avatar
Malc,
I stand corrected! I've just reviewed my pics from 10 years ago, and I did take off the door panel and then accessed the plugs from the front corner access aperture. See my pic below
Remember to tie a piece of string to stop the plugs falling into the door aperture whilst the mirror is out.
Paul
Old Oct 22, 2024 | 08:47 AM
malc4d's Avatar
Is that Solent blue ?
How do you move the chromed bracket without destroying the leather on the door pull ?
Old Oct 22, 2024 | 09:32 AM
ptjs1's Avatar
Sapphire Blue,
And.... extremely carefully!! Pull it back the smallest amount to enable you to get to the screw head. And carefully come at the screw from an angle (not ideal) to minimise the amount that you need to move that chrome collar. Maybe even lubricate the leather with a bit of polish first to avoid it catching and ripping.
Paul
Old Oct 22, 2024 | 10:25 AM
Greg in France's Avatar
Originally Posted by ptjs1
Sapphire Blue,
Paul
And replace the original pozi setscrew with an Allen key headed one. This is far easier to undo and also means the collar does not have to be pulled back so far the next time.
Old Oct 28, 2024 | 05:11 AM
rgp's Avatar
rgp
I drilled holes in both colliers after I had the armrests recovered. I was going to fit a blank grommet in the hole but it doesn't show.
Old Oct 28, 2024 | 07:14 AM
Great idea, Rex!
Old Oct 28, 2024 | 12:44 PM
malc4d's Avatar
Ok. I finally got down on my knees and attacked the doors to replace the mirrors. Thanks all who posted about this job.
Sooooo, not as bad as l thought it would be. The facelift car doesn't have that convenient screw hole as the pre-facelift car,
i had to carefully unclip the chrome cover and slowly move it away up the arm to free access to the screw. unscrewed a couple of under the arm box lifted upwards and off it came... just unplugged the door light and had access to the mirror plugs was easy. The plugs on my early '91 were clipped onto a metal bracket and the mirror easily unplugged and pulled through the door. Fitting the new mirror was simply the reverse procedure.
Peter Petras
20
Dec 24, 2023 11:25 PM
cornishcat
Dec 23, 2023 01:19 PM
SJP
Mark V - X 420G
Dec 31, 2021 12:08 AM
Richard A. Stolfa
XJ40 ( XJ81 )
May 3, 2018 01:55 PM
